3pt woodsplitter vs Gasoline powered
   / 3pt woodsplitter vs Gasoline powered #71
Manual is available at TSC's website for the splitter - there's a link in the description.
   / 3pt woodsplitter vs Gasoline powered #72
Thanks but mine is not 3pt hitch it is a 28 ton tow behind w/ Honda 190cc Horazontal engine.
My bad, I reflexively jumped off from the "3pt woodsplitter" in your thread title. But your description doesn't quite fit the manual selection. The Honda 190 is typically in the 25 ton. The 28 ton gets the Honda 240. So here are both manuals. It was my understanding that Huskees are actually rebadged SpeeCo splitters. But apparently they do a little cost cutting on the Huskee line. So here's the Huskee manual as well
//greg//
  • 25 Ton, 401625PH, REV 1, Jan_2010-Current.pdf
  • 28 Ton, 401628PH, REV 0, Jan_2010 Current.pdf
  • 2152374_Man1.pdf
   / 3pt woodsplitter vs Gasoline powered #73
Maybe that's the deal. Problem with the 240 and they stuck a 190 on it. If so, it will be under-powered. And no warranty? What's up with that?
Ian
   / 3pt woodsplitter vs Gasoline powered #76
Seafoam is about 50% light oil with some naptha and alcohol mixed in. It may do something, who knows.
  • MSDS_seafoam_EN.pdf
Ian
Well to be honest i thought it was a 190 but it could have been a 240? One of them had a 190 and maybe I got confused. as far as the warrenty yea I know H.D AND lOWES both said that even if they had a used one it would still have the warrenty with it. But at this location they asst manager said there would be no warrenty.So either walk away or buy? I bought .
I will get some they say its good stuff.
//greg//
Thanks I will see if one will work for mine.I will look now.
Well here it is we just got her home looks ok runs ok just need to get her off the trailer and into some wood. Also need to sell the rototiller to make a little extra room and make momma happy ha ha
Deere 317G (A50120)
Deere 317G (A50120)
2017 GENIE GS-2646 (A52472)
2017 GENIE GS-2646...
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
International Harvester Farmall FC (A50514)
International...
Farmall A Tractor w/Belly Mower (AS IS) (A50774)
Farmall A Tractor...
Cyclone Rake Yard Vacuum (A50515)
Cyclone Rake Yard...
