Water Hammer Arrestor
   / Water Hammer Arrestor
What kind of waterers did you install? I am getting ready to put in a single ritchie unit. I have about 350 ft of 1.5 inch, tapped between the well and tank out to a frost-free. I am planning to tee off of that line, reduce to size, and install the shut off valve. I have had no problem with the frost free fixture provinding any issues, nor have I had any issues with hammering at the well tank.
I guess I am wondering if I need to install one of these...
I installed Drinking Posts, I posted this thread on it last fall.
You won't have hammer with a manually operated valve because it closes so slowly (relatively speaking). I'm not familiar with Ritchie units, but if it has a spring or solenoid operated valve, you'll need an arrestor. The issue is how fast the valve closes: if it closes really fast then it creates a shock wave that causes the hammering. If you're T'ing off an existing line, I'd put one larger arrestor at the end of your longest run, and a smaller arrestor at the end of the run for the waterer. The issue is that the column of water moving down that long length of pipe has to stop suddenly so the best place to absorb that shock is at the end of the long run. If you can't get to the end of the longer run, just put a large one by the arrestor and hope that does the trick. I chose to put in two instead of one because they're cheap compared to the labor of digging the whole thing up if one fails.
   / Water Hammer Arrestor #12
There must be some other problem that has caused them to fall out of favor, or maybe there's a political lobby for arrestors.
/QUOTE]
Dead water and bacterial growth.:thumbsup:
   / Water Hammer Arrestor #13
I would protect them or mark the location. WH arrestors do not last forever. I have replaced them after 2 years already.
I've got a survey I keep updated with the location of everything, so I know right where it's at. I also throw a piece of pvc a few inches above it so I hit that first with the shovel.
I bought commercial grade units from Watts, hopefully they'll last longer than the stuff they sell at the big box stores. If you're replacing them every 2 years they might be getting damaged by soldering heat during installation, or if they're even slightly dented or deformed it doesn't allow the piston and oring to seal properly.
   / Water Hammer Arrestor #15
Im talking about Zurn WH arrestors, and I assure you they are installed properly, Im a journeyman plumber. Depending on how often they are used they can wear out sooner than you would think.
   / Water Hammer Arrestor #16
Beezfun, where is " around here " ? I am in S Ilinois and installing 96 riser type arrestors tomorrow. I have passed inspection on 5 8plex apartment buildings at this site since Jan 1, 2012.
DuPage county, next county west of Chicago.
   / Water Hammer Arrestor #18
/QUOTE]
Can you explain this please...They WERE Legal here, but haven't had occassion to check the regs? yes, I realize you cannot put them in a ditch. I have had a watts before...Commercially they are putting a captive air bladder into the lines on this building..about 3 gallons.
Interesting design, they use a stainless bellows to isolate the air chamber from the water. I'm guessing they're really expensive. I've never understood why they don't just use a shock absorber mechanism like cars use in these things, then you don't have to worry about leaking air.
The water itself could be the fluid, the perforated disk would be forced through the water and returned by the spring. I installed two chambers to hedge my bet against a premature failure, maybe I should have installed more extras. Once I build my new barn I can move the arrestors above ground so they'll be easy to get at if they fail.
   / Water Hammer Arrestor #20
The upright air pocket piping does not have water through flow. There are fears the stagnate water may allow bacteria to multiply and eventually contaminate the water line.:D
at one time they were probably manditory in the regulations.
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
Land Pride RCR1260 (A53317)
Land Pride RCR1260...
Tote of Misc Tools (A57454)
Tote of Misc Tools...
New/Unused 12V Diesel Pump with 50ft Hose (A57454)
New/Unused 12V...
2016 Hino 195h Truck, VIN # JHHSPM2H9GK001609 (A57453)
2016 Hino 195h...
Anvil (A57454)
Anvil (A57454)
