Adding Hydraulic Female QD to tractor
   / Adding Hydraulic Female QD to tractor #1
Furu
I am adding several hydraulic female QD's (eight) to some equipment.
Deere has a part number they use that has a series of grooves machined into the body for snap rings so as to make it very easy to mount on a plate for rigidity. So far I have found no manufacturer that admits to making them so I think they make them for JD under license and do not sell them elsewhere.
I could buy them from JD but they are VERY expensive compared to the normal identical, minus the groove, QD.
I have been looking at using a bulkhead fitting to adapt from the hydraulic supply lines to the QD and thus the fitting mounted to the bulkhead would supply the rigid mount. Problem is I have failed at finding the bulkhead fittings I want. I can fit JIC to JIC and NPT to NPT but I want a male ORB to ORBS or ORB to NPT in a bulkhead fitting. I want to avoid NPT if I can though. I know I could build a xmas tree of fittings/adapters but don't have the room to do so. Does anyone have a source/supplier to do male ORB to male ORFS bulkhead fittings?
Or ORB to ORB bulkhead fittings.
J_J
Discount Hydraulic was my first go to site but they do not have them. Only JIC/JIC and NPT/NPT in bulkhead design. That is why I sent the query.
Thanks for the royal supply site it looks like they carry them, bulkhead ORFS/ORB, just not in the sizes that I am looking for. Both smaller and larger but not my size. I will call them and see what gives.
Thanks
   / Adding Hydraulic Female QD to tractor #4
I did exactly what you are planning. I bought JIC bulkhead fittings. On the short side threads I put on an O-Ring and you will have an ORB fitting (threads are the same). I bought female quick couplers with female ORB threads. On the other side, after the nut holds this to the bulkhead (angle iron in my case) I used hydraulic hose with the correct size female JIC swivel fitting. :)
So you were able to get a good seal with an O-ring on a JIC fitting? That is interesting as I did not think the shelf on the JIC fitting nut would hold the O-ring against the O-ring chamfer properly. Will have to consider it.
   / Adding Hydraulic Female QD to tractor #6
Yes, no leaks. Also have done the same with hoses that had male fixed JIC ends. added the correct O-Ring and used in ORB female port. Maybe just lucky!
2007 Kenworth Tandem Axle Road Tractor (A47477)
2007 Kenworth...
2019 LOAD TRAIL 35+5 GOOSENECK TRAILER (A58216)
2019 LOAD TRAIL...
2821 (A58376)
2821 (A58376)
2012 Chevrolet Equinox SUV (A56859)
2012 Chevrolet...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
SDLD25 MINI DUMPER (A58216)
SDLD25 MINI DUMPER...
