What could do this to a 3720??
   / What could do this to a 3720?? #2
Rolled off a high trailer or driven off a cliff or loading dock?
It did not roll over...
:confused2:
   / What could do this to a 3720?? #3
I have head that when operating backhoes on tractors the operator should not raise the rear wheels off the ground with the stabilizers. The stabiliziers should just be deployed enough to stop the lateral movement.
Raising the wheels off of the ground can put excess strain on the tractor frame. On some of these tractors the frame is not continuous from front to rear. Just my thoughts.
   / What could do this to a 3720?? #4
A break @ the bell housing is not uncommom as you might think. It could have been stuck and pulled into by another tractor. Thats how most that I have heard of breaking have happened.
   / What could do this to a 3720?? #5
I suspect rolled off a trailer or ledge with substantial vertical shock on the bellhousing. I really doubt the backhoe or tractor hydraulics could have generated the force even in a bind to compromise the bellhousing such as that.
John M
   / What could do this to a 3720?? #6
John M
Thats the thing about these new flat decked tractors. There really isn't a bell housing. Look at the pictures. There is just something like a steel torsion box under the deck that a small drive shaft runs through to the transmission box under the seat. It is not built like the old cast iron tractors where the drive line was the frame. That said, I think the new style frames are stronger for the weight and more functional. Only down side is they aren't as heavy. So, in this case, the.deck frame was pulled apart from the rear of the.tractor. I just wonder what that strange green stuff was on the engine parts.
   / What could do this to a 3720?? #7
Wife found out the husband was cheating and cut his beloved 3720 in half to get back at him:laughing:
   / What could do this to a 3720?? #8
She a mean woman..:shocked:
   / What could do this to a 3720?? #10
Raising the wheels off of the ground can put excess strain on the tractor frame. On some of these tractors the frame is not continuous from from to rear. Just my thoughts.
I suspect this is the correct answer...
2015 Chevrolet Express Passenger Bus (A50323)
2015 Chevrolet...
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
2022 GTS FS35-G2 Flex Draper Header (A50657)
2022 GTS FS35-G2...
2011 MAMMOTH UTILITY (A50854)
2011 MAMMOTH...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2017 Ford F-550 Bucket Truck - 4x4, Powerstroke Diesel, Versalift VST47, 52FT Reach (A51039)
2017 Ford F-550...
