Valby 150 Belt Replacement
   / Valby 150 Belt Replacement #1
Red Horse
Bolton, MA
Deere 655ZTrak, Deere 4720 Cab, 400 X LT 155
Well after some heavy use today, just about to finish big pile of brush and had a belt failure. Anyone have any suggestions on changing these things? Looks like a nasty job. Also I did a search and an old posting indicated a NAP A48 1/2x 50 belt is the correct replacement. I have an e-mail out to Northeast Implement.
Just trying to get a jump on things.
Thx
   / Valby 150 Belt Replacement #2
Here's a link to download the manual... Not certain if the desired information is in it.
http://www.google.com/url?sa=t&rct=j&q=valby%20chipper%20150&source=web&cd=7&ved=0CGQQFjAG&url=http%3A%2F%2Fwww.farmiwoodchippers.com%2Fdownloads%2F11-farmi-valby-ch150-manual-parts-breakdown%2Fdownload.html&ei=G1luT5yuJa6A2QWLjq3xAQ&usg=AFQjCNGvVQLcfHmqd35mDw3UNxa-ivzzDg
Another site had this posted:
Posted by bill c on November 30, 2010 at 20:16:51 from (72.83.76.127):
In Reply to: Valby 150 Chipper belts posted by bill c on November 26, 2010 at 13:29:22:
Valby Dealer said to use NAPA A48 belts(1/2x50)
Here's the link: http://www.ytmag.com/cgi-bin/viewit.cgi?bd=implment&th=188065
Here's the link: Valby 150 Chipper belts - Yesterday's Tractor Co.
Mo,
Thx for taking the time.:thumbsup:
   / Valby 150 Belt Replacement #4
Requires a fair bit of disassembly. The loosen the tensioner and roll the other belts off the pulley. remove bearing caps and hoist the flywheel up with a chain lift such that you can extract old belts and insert new ones. reseat flywheel on bearings, replace caps, torque caps down, retension.
easy peasy.:laughing:
DH-Manual says drop the top pulley first- I gather you are saying that is not a requirement. Kind of looks like there is enough room to pull the flywheel up mjust enough to get the belts on.
   / Valby 150 Belt Replacement #6
just enough, as I recall. look it over closely, your year/model may be different than mine.
2024 CATERPILLAR 255 SKID STEER (A52705)
2024 CATERPILLAR...
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
SKID STEER HYDRAULIC TREE PULLER (A53843)
SKID STEER...
2013 Ford Edge (A55853)
2013 Ford Edge...
2014 Ford F-250 Ext. Cab Pickup Truck (A54814)
2014 Ford F-250...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
