Valby 150 Belt Replacement
   / Valby 150 Belt Replacement #1
Red Horse
Bolton, MA
Deere 655ZTrak, Deere 4720 Cab, 400 X LT 155
Well after some heavy use today, just about to finish big pile of brush and had a belt failure. Anyone have any suggestions on changing these things? Looks like a nasty job. Also I did a search and an old posting indicated a NAP A48 1/2x 50 belt is the correct replacement. I have an e-mail out to Northeast Implement.
Just trying to get a jump on things.
Thx
   / Valby 150 Belt Replacement #2
Here's a link to download the manual... Not certain if the desired information is in it.
http://www.google.com/url?sa=t&rct=j&q=valby%20chipper%20150&source=web&cd=7&ved=0CGQQFjAG&url=http%3A%2F%2Fwww.farmiwoodchippers.com%2Fdownloads%2F11-farmi-valby-ch150-manual-parts-breakdown%2Fdownload.html&ei=G1luT5yuJa6A2QWLjq3xAQ&usg=AFQjCNGvVQLcfHmqd35mDw3UNxa-ivzzDg
Another site had this posted:
Posted by bill c on November 30, 2010 at 20:16:51 from (72.83.76.127):
In Reply to: Valby 150 Chipper belts posted by bill c on November 26, 2010 at 13:29:22:
Valby Dealer said to use NAPA A48 belts(1/2x50)
Here's the link: http://www.ytmag.com/cgi-bin/viewit.cgi?bd=implment&th=188065
Here's the link: Valby 150 Chipper belts - Yesterday's Tractor Co.
Mo,
Thx for taking the time.:thumbsup:
   / Valby 150 Belt Replacement #4
Requires a fair bit of disassembly. The loosen the tensioner and roll the other belts off the pulley. remove bearing caps and hoist the flywheel up with a chain lift such that you can extract old belts and insert new ones. reseat flywheel on bearings, replace caps, torque caps down, retension.
easy peasy.:laughing:
DH-Manual says drop the top pulley first- I gather you are saying that is not a requirement. Kind of looks like there is enough room to pull the flywheel up mjust enough to get the belts on.
   / Valby 150 Belt Replacement #6
just enough, as I recall. look it over closely, your year/model may be different than mine.
New Holland TN75S 4WD 75HP Loader Utility Tractor (A55787)
New Holland TN75S...
Ford 655C 2WD Cab Backhoe (A55218)
Ford 655C 2WD Cab...
BUNDLE OF 2" X 2" X 34" ANGLE IRON (A54756)
BUNDLE OF 2" X 2"...
2014 Volkswagen Touareg - Turbo Diesel - AWD - 189,609 miles (A55218)
2014 Volkswagen...
2022 McConnel TRAXX RC28 43in. Remote Controlled Slope Mower (A54815)
2022 McConnel...
Yanmar YM1500 Tractor w/Loader (RUNS) (A50775)
Yanmar YM1500...
