conlrol valve on bolens ht-20
   / conlrol valve on bolens ht-20 #1
jimrobert
mpls.mn.
1976 bolens ht-20
hi this is my first posting .i was thinking of connecting a second hydro. control valve on my bolens ht-20 . i was thinking that hooking them in sieres . then i could run another cylinder. any ideas? thanks
   / conlrol valve on bolens ht-20 #2
Welcome to TBN. :)
   / conlrol valve on bolens ht-20 #5
If your tractor is open center hyd, then you can add valves in series. The first valve should have a relief and a PB port to feed the next valve. Tank ports should go to tank.
You could also replace your current valve with a two spool valve with PB, regen and float, and use the current valve as the second valve.
2013 Infiniti M37 Sedan (A53424)
2013 Infiniti M37...
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
2009 Honda Pilot AWD SUV (A53424)
2009 Honda Pilot...
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
2007 Yamaha Rhino 660 (A55218)
2007 Yamaha Rhino...
TAKEUCHI TL12R2 SKID STEER (A52705)
TAKEUCHI TL12R2...
