To load or not to load; That is the question.
   / To load or not to load; That is the question. #21
I hadn't thought of that, but...
If the backhoe bucket were in the ground and the operator was pulling up to remove a tree root or rock, the downward force on the outriggers could be much greater the the several hundred pounds of liquid ballast.
   / To load or not to load; That is the question. #22
Only thing I could see is the braking issue but not the lug nut story???
On these little tractors its hard to keep the rear on the ground during loader operations no matter what you have on the back.
   / To load or not to load; That is the question. #23
These aren't commercial TLBs anyway.... you shouldn't be jacking the tractor off the ground when using the backhoe, so I don't see an issue.
   / To load or not to load; That is the question. #24
Getting back to the original question - loading the rear tires:
Are you almost totally certain that you'll never get a flat tire? If the chances of running over a Honey Locust or Hawthorn thorn(s) are about zero, then load the tires.
   / To load or not to load; That is the question. #25
Load them and after using the backhoe check your lug nuts and see if any loosened up. I don't see them loosening but who knows, better safe than sorry.
   / To load or not to load; That is the question. #26
I've read this about not using loaded tires with a back hoe as well.
I ordered my machine loaded with Rimguard, and I intend to throw some wheel weights on as well- I guess I'll really be putting this to the test!
   / To load or not to load; That is the question. #27
I wonder why they would recommend removing the ballast when using the backhoe.
Normally the outriggers pick up the rear end of the tractor when working. Just a guess but maybe they are covering some cylinder warranty issues?
   / To load or not to load; That is the question. #28
IME the outriggers are more than able to lift the machine's tires off the ground, but my manual says they aren't to be used for this purpose- just to stabilize, in which case I don't see where more tire weight makes much difference.
   / To load or not to load; That is the question. #29
Hence the warranty claim issue. I don't "Know" why they say that, just guessing. Perhaps the dealer might shed some light on it. Are you enjoying the machine?
   / To load or not to load; That is the question. #30
I haven't received my 1026R yet, but I've read that this topic applies the same way it did to my 4310. If I was doing lite work with the 4310 hoe I wouldn't even bother to drop the stabilizers. The newer stabilizers look a little less hefty- so if I had to make a guess, I would say the warnings have to do with either damaging the stabilizers or the subframe.
UNUSED FUTURE 24" HYD TILT MINI EXCAVATOR BUCKET (A51244)
UNUSED FUTURE 24"...
2016 Komatsu PC1250LC-8 Hydraulic Excavator (A50322)
2016 Komatsu...
Bobcat Skidloader Breaker (A50774)
Bobcat Skidloader...
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
2025 GIYI GY-X380 Trencher Mini Skid Steer Attachment (A50322)
2025 GIYI GY-X380...
BUNDLE OF USED GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF USED...
