3-point attachment rentals
   / 3-point attachment rentals #11
Could you please tell me the name of the place you found? I wasn't aware of any of the rental places in my area carrying anything for 3-point hitches, in my area.
Thanks
Rob
Not sure if that was for me or not. If so i know ahearn equipment in spencer toreku tractor in ayer and cb (think thats it) in nh all rent. Someone else said theres a good place in s nh that rents, but i haven't got the name.
   / 3-point attachment rentals #14
What town are you in?
   / 3-point attachment rentals #15
I recently rented a rake and my main word of advise is plan your work so you get as much done during the rental period.
FYI
The rental rule of thumb is: week end rate is 1.5 X daily rate
so week ends are less stressful on the ole bod!
Also;
daily rate = 1% of purchase price
weekly = 5 X daily rate
monthly = 3 x weekly rate.
   / 3-point attachment rentals #16
Not sure that rule applies to a 3pt tiller. The rates seem to be about $100 per day from what I have found. A new tiller (60 inch) shouldn't cost more than $3000. If i could rent one for $30 I certainly wouldn't buy one. As it stands, I am on the fence.
I guess you have to weigh the cost of a new one over how many times you use the impliment. I won't be using the tiller all that much, so I can't justify buying one. I can however justify spending the $135.00 to rent this one time.
   / 3-point attachment rentals #19
Agree. Rates around here are similar, 100 - 200 per day for most impliments. I view it as a good way to try something out or get specialized equipment, but if ill use it regularly i buy it to save the hassle of renting.
   / 3-point attachment rentals #20
The 'rule of thumb' formula that I mentioned earlier was just that. A general rule.
High maintenance or high wear items varied from the rule.
Cutting tools always had a wear limit and you paid separately for wear above a certain limit. If you took a chunk of blade out on a mower blade, you paid for it!
Break a drill bit and it was yours etc.
Rotary impact tools (Kango) always rented higher due to maintenance issues.
The guiding rule was; Rent to use and not to abuse.
excavator trenching bucket- one bucket per lot (A56438)
excavator...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A59228)
2025 Kivel 48in...
2010 MULTIQUIP 25KW GENERATOR (A58214)
2010 MULTIQUIP...
2007 Heil Heavy Duty Aluminum Tank Trailer (A56438)
2007 Heil Heavy...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2020 Case 5550 Trident (A56438)
2020 Case 5550...
