Bush Hog gear box oil change
   / Bush Hog gear box oil change #1
nazbom2
Spotsylvania, VA
Yanmar YM 2000
How often should you change the gearbox oil on a rotary mower? Are they like rear ends and only do it if it get water in there and at the interval??
   / Bush Hog gear box oil change #2
at least ever couple ecades.. or when dry or wet.. :)
if you went by book spec you might see a 600 hr interval.. etc..
   / Bush Hog gear box oil change #3
I check mine for water every spring and change it as needed.. I got lucky and 4 bolts hold the top of the gear box on, so it is easy to access.. When it needs to be changed I just suck it out as best as possible, soak the rest up with a rag, and then refill
Brian
   / Bush Hog gear box oil change #5
I try to do it at the end of every season though sometimes I go two seasons, It always looks good coming out. Rather have it running smooth than not running at all
   / Bush Hog gear box oil change #6
+1 Try to catch mine at the start of every season, but don't always happen;)
   / Bush Hog gear box oil change #7
my jd hogs have top covers that come off.. that's a plus!
   / Bush Hog gear box oil change #8
Get fully synthetic gear oil. (available at Advance auto)Then check it yearly and change it every 5 years.
   / Bush Hog gear box oil change #9
Is synthetic oil not real oil?
   / Bush Hog gear box oil change #10
it's oil, just depends on how it is made or refinded or blemded as to if it is fully synthetic or hydrocracked.. etc...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
3 Point Hitch Boom Pole (A51573)
3 Point Hitch Boom...
2008 Nissan Sentra Sedan (A51694)
2008 Nissan Sentra...
2018 FORD EXPEDITION (A51406)
2018 FORD...
