B3300SU Transmission Surge
   / B3300SU Transmission Surge #11
You got lucky, my 2620 I had was smooth as silk yet my 3200 is jerky no matter what rpm it is at.
you running the super udt fluid in the hyd. trans. with kubota filters? just wondering for my info.
   / B3300SU Transmission Surge #12
I changed the fluid at 50 hrs and went with CaseIH Hy-tran fluid but I did not notice any difference. As for filters I stick with Kubota filters. Expensive yes but I consider them excellent quality.:thumbsup:
   / B3300SU Transmission Surge #13
I use Super-UDT and Kubota filters and always have. The transmission lurch only happens when the Hydraulic fluid is not up to operating temperature. Then it's pretty much gone. I use Lo 60% Med 39% and Hi about 1% of the time. So. It's a none issue for me anyway.
   / B3300SU Transmission Surge #14
same with me. in fact i only notice the problem with my b7800 when i am pulling out of my shed first thing=usually not fully warmed up and/or i have it at low rpms just pulling out. it will do it once with in the first 5 feet i move it then that is it. anyother time it has happened to me is if i was transporting it in high range and i get lazy and try to take it up a hill i should have shifted to medium on. other then that i never have this surge problem. i run my rpms atleast 2300. gears= low=50% med=49% high=1%.
not sure, but does it have a two stage pump and it might be kicking between stages causing this surge or lurch forward?
   / B3300SU Transmission Surge #15
i actually just priced kubota filters against wix (napa) and to my surporise, the kubota filters were not any more expensive. some of napa's filters were a little more (not much), some of kubota's filters were more (not much). i priced all the filters, air, oil, hyd/trans, fuel. i am in the north east. maybe prices with competitors vary elsewhere??? i too will stick with the kubota filters.:thumbsup:
YARD MACHINES MOWER (A50854)
YARD MACHINES...
2015 KOMATSU PC170LC-10 EXCAVATOR (A50458)
2015 KOMATSU...
2017 Ford F550 4x4 Bucket Truck - 45FT Terex TL40 Boom, Powerstroke Diesel, Utility Bed, 54K Miles (A51039)
2017 Ford F550 4x4...
2004 KENWORTH BUCKET TRUCK(INOPERABLE) (A50854)
2004 KENWORTH...
Case 84in Hydraulic Hopper Sweeper/Broom Skid Steer Attachment (A49461)
Case 84in...
1995 FORD F-800 BOX TRUCK (A50854)
1995 FORD F-800...
