B3300SU Transmission Surge
   / B3300SU Transmission Surge #11
You got lucky, my 2620 I had was smooth as silk yet my 3200 is jerky no matter what rpm it is at.
you running the super udt fluid in the hyd. trans. with kubota filters? just wondering for my info.
   / B3300SU Transmission Surge #12
I changed the fluid at 50 hrs and went with CaseIH Hy-tran fluid but I did not notice any difference. As for filters I stick with Kubota filters. Expensive yes but I consider them excellent quality.:thumbsup:
   / B3300SU Transmission Surge #13
I use Super-UDT and Kubota filters and always have. The transmission lurch only happens when the Hydraulic fluid is not up to operating temperature. Then it's pretty much gone. I use Lo 60% Med 39% and Hi about 1% of the time. So. It's a none issue for me anyway.
   / B3300SU Transmission Surge #14
same with me. in fact i only notice the problem with my b7800 when i am pulling out of my shed first thing=usually not fully warmed up and/or i have it at low rpms just pulling out. it will do it once with in the first 5 feet i move it then that is it. anyother time it has happened to me is if i was transporting it in high range and i get lazy and try to take it up a hill i should have shifted to medium on. other then that i never have this surge problem. i run my rpms atleast 2300. gears= low=50% med=49% high=1%.
not sure, but does it have a two stage pump and it might be kicking between stages causing this surge or lurch forward?
   / B3300SU Transmission Surge #15
i actually just priced kubota filters against wix (napa) and to my surporise, the kubota filters were not any more expensive. some of napa's filters were a little more (not much), some of kubota's filters were more (not much). i priced all the filters, air, oil, hyd/trans, fuel. i am in the north east. maybe prices with competitors vary elsewhere??? i too will stick with the kubota filters.:thumbsup:
2020 HINO 195 CAB AND CHASSIS (A51222)
2020 HINO 195 CAB...
John Deere Hayrack (A50515)
John Deere Hayrack...
2019 Ford Fusion SEL Sedan (A50324)
2019 Ford Fusion...
2012 Chevrolet Traverse SUV (A50324)
2012 Chevrolet...
1994 Toyota 6000lbs 2 Stage Forklift (A52128)
1994 Toyota...
15 FT Trailer (A50322)
