Garage Floor Coating
   / Garage Floor Coating #1
Bird
Rest in Peace
Corinth, Texas
This is my latest, and hopefully last, project before the really hot weather arrives. I'd never heard of RustOleum Epoxy Shield garage floor coating until a daughter and son-in-law did their garage floor with it. There are two colors. They used the tan and I used the gray. Day before yesterday, I moved everything out of the garage, yesterday son-in-law came and helped me scrub, etch, and rinse the floor. Then today he came back and we applied the coating. First picture is obviously the "before" picture and the other 3 are today. Has anyone else used this stuff?
   / Garage Floor Coating #2
I used the tan about two years ago and it seems a very good product. Obviously with any coating, prep is key. I'd use it again.
   / Garage Floor Coating #3
I wonder how soon you can use it after a new floor is put down? Also if I may ask, how expensive was it and what kind of coverage did you get ?
   / Garage Floor Coating #4
Bird,
Once it cures well, dump a pale of water on it.
Be sure you can see the water ok and that it is not slippery.
Don't need any broken hips in the garage.
Ron
   / Garage Floor Coating #5
Bird,
Ron
I have heard it is very slippery. I have 2 boxes of it,( Christmas gift) and have had for a while, but I have hesitated on putting it down..
James K0UA
   / Garage Floor Coating #6
Looks real good Bird:thumbsup: Cant tell from the photos, but I know on some floorings you can add a slip resistant granule or "chips" to add some slip protection.
I use a product called "Shark Grip" for ramps on store approaches and on some occasions even fine sand or glass beads, ends up like 100 grit sandpaper .
   / Garage Floor Coating #7
I was wondering if you could add a little fine white clean sand to the mix. to give it some more grip.
James K0UA
   / Garage Floor Coating #8
I've had it for about six years. There's some chipping just outside the garage door where it's exposed to the elements (I don't think it's intended for outdoor use), but otherwise it has held up very well. I would definitely recommend it.
   / Garage Floor Coating #9
Looks fantastic Bird..
   / Garage Floor Coating #10
Fine sand would do it or granite dust, similar to the non slip surface paint that costs a fortune.
   / Garage Floor Coating #11
Dennis,
That works. Can he top coat his paint with "Shark Grip" without changing the color? It will probably make it much harder to clean the floor but a lot safer for him and his wife.
Ron
   / Garage Floor Coating #12
My dad did his about 12 years ago. Huge mistake. Slippery and water just stands for days after snow melt, ect. Also very slick with saw dust on it when working on projects.
Chris
Chris
They do have some stuff to add to the paint when you mix it to keep it from being slippery, but I didn't use it. Of course in my case, the only water will be if I wash out the garage, or what drips off the vehicles if we come in when it's raining. And all my sawdust production is in the shop at the back of the house instead of in the garage.:D
The instructions say drying time depends on temperature and humidity (no surprises there), but dry enough for "light foot traffic in 12-16 hours, heavy items and normal foot traffic in 24-48 hours, FOR FULL CURE AND VEHICLE TRAFFIC, ALLOW 3 DAYS."
I intend to move the washer & dryer back in there Tuesday or Wednesday, and since I'm in no hurry, I'll probably wait a week before parking the vehicles back in there to give it plenty of time to cure.
I bought the 2-gallon kit from Home Depot for $107 plus tax, but we had over half a gallon left over. Of course the one gallon kit ($65.97) wouldn't have been quite enough.
Of course, in addition to the kit that includes the base, the activator, the etching powder to mix with water, the decorative chips that you may use (I did) or not, an instruction sheet, and an instruction DVD, you need a stiff bristle brush, some kind of degreaser (naturally the instructions mention theirs but I called and the guy suggested any degreaser, including Simple Green, which I had and used), a squeegee to push the excess water out when you finish scrubbing and etching, a 1/2" nap 9" roller and pan, and a paint brush.
   / Garage Floor Coating #15
So THAT'S what a clean garage looks like! :shocked::D
Looks very nice! I bet it will be very easy to clean.
Joe
   / Garage Floor Coating #16
I put it on my garage floor about 8 yrs ago, am happy with it. I put the chips on it, I like the looks of it. I used the leftover and did a portion of my basement floor, it is really nice there.
I added a pic showing before and after section of floor.
Buckeye, the light and angle of my pictures doesn't show the chips as well as your picture, but mine does look just like yours. The kit comes with plenty of those "decorative chips".
   / Garage Floor Coating #18
like it//////////
   / Garage Floor Coating #19
Dennis,
Ron
Ron, I bet they have a clear finish he could use, or he could re-top it, same color with a little additive.
Shark grip is nice since it doesn't effect sweeping near as much as sand or a coarser grit, but seems to work best when the surface is damp. High heels will still pose a problem, so Bird make sure you aint wearing high heels if its wet!!:D
   / Garage Floor Coating #20
If this is what HD sells, then I put it down in a floor in FL. Looks good but I found that the hot tires after driving back into the garage would lift the paint....anyone else?
I put carpet runner pcs. down under the tires which seem to do the trick.
2012 John Deere 6170R (A57148)
2012 John Deere...
2025 JMR 36in Bucket Mini Skid Steer Attachment (A59228)
2025 JMR 36in...
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
2014 Club Car Carryall 295 4x4 Utility Cart (A59228)
2014 Club Car...
Dayton 32965 80-Gallon Horizontal Air Compressor, 22 Volts, 5 HP, 2 Stage, 3 Phase (A59076)
Dayton 32965...
2019 CATERPILLAR 313FL GC EXCAVATOR (A60429)
2019 CATERPILLAR...
