Eddie Walker: If you see this post, please feel free to add your comments either in agreement or disagreement. Your experience probably is closer to mine than anybody else.
I don't have a dump trailer, so I'm not sure what tha't like. With my dump truck, I can load it with the backhoe and drive it to where I want it so much faster that it's not even comparable. The only time I haul dirt with my bucket is for very small jobs, or very short distances. A hundred yards and I'm using the dump truck.
I've also found that if the dirt has sat for awhile and compacted itself, or if I'm digging new dirt, it's faster and easier to dig and load with the hoe bucket then to use the front bucket. It takes too much time to load it, drive to the dump truck, dump it and do it all over again.
It just takes a few seconds to get off the backhoe and into the dump truck, so the transition from one to the other really isn't a factor. When my Dad is here, he will drive the dump truck, but overall, I don't think we really save much time. While he's dumping the load, I reposition and clean up the loading area, but mostly I just sit and wait. If I could trust him on the dozer, I would load and drive while he worked at spreading the dirt. Or if I could trust him to load without digging a deeper hole or doing something that I have to come back and undo, then I would be on the dozer. That would speed things up considerably.
As for the hoses, it only gets worse. You will get faster at the easy hoses, but there are some under your backhoe that will require five hoses to come off to get to the one that is leaking!!!!
Field repairs make it even more memorable
To cut the hoses, I like to use my cordless sawzall with a fine tooth, metal cutting blade. I've found that once the hose is cut, I can sometimes get it off my just turning the hose with my hand. Other times, it just gives me the room to get in there and get enough leverage to break it loose.
Hoses are nothing compared to rebuilding the cylinders. The worse ones are the ones that move the hoe from side to side. That is just pure MISERY!!!!
Eddie
