radioman
Super Member
Hi guys,
My main concern is the rear hitch. It is a 3 point and claimed to be a Class 1 but I've read that it is possibly a Class 1 limited. How concerned should I be about this? Does anyone have definitive data on this? I can't find much info on it.
Darren
I wouldn't worry too much about the word limited for cat. its just the weight and height you can lift things. You can't exactly put a 6-8 foot bush hog on it, but a 4 footer you can. you can try to put a full size post hole digger, but you may not be able to clear ground with auger tip. they have jr versions that is better sized. you can't exactly put a 6-7 foot tiller on it and expect to let it run in heavy clay with roots, but they have 4 footers that is perfect for it. you may not be able to lift 2 ton round bales on spear, but you can lift half ton no problems etc.
Its all about sizing for that BX.
Dag,
I'm no big tractor expert, but if you are buying that BX2230 with intentions of putting a backhoe on it down the road--you are buying yourself trouble. You'll end up having to buy an after market frame and backhoe, spending $5,000 or more.
If you really want something for a backhoe, then buy it now. Look at a used BX24, it's a loader and backhoe with 23 hps. Kubota made em with full frames to withstand the stress of the backhoe. Used ones run from 10-12K.
Good luck.
Not exactly trouble - but it sure it alot easier to get a BX with BH already designed to go with it. most people don't gt BH later, but rather rent. If they do - woods brand BH seems to be thee only game in town for BX's.
Ok, the questions/concerns:
yup normal as you guessed it, just like most tractors and mine.1. There was a black puff of smoke at start. It was momentary and ran clean from that point on. Each start had a little puff. I assume that is normal for a diesel. Please tell me if I'm wrong.
2.The selectors needs to be lined up. I wouldnt try to shift from mid to rear while running, but if it won't shift - just bump the pto engager and let it stop and theen shift. it should shift smoothly.The PTO selector (mid, back, mid and back) worked great in mid or back but I couldn't get the selector to operate "mid and back". When I selected that position it sounded like a typical clutch grind. Any thoughts? mid or back worked perfectly.
I don't think its the bulbs - I think you will need a new switch as its a common problem on that model.3. There was a wiring problem with the turn signals/hazards or they had the wrong bulbs. Headlights worked perfectly. I am thinking they may have selected the wrong bulbs and didn't install the dual filiment or something.
You can negotiate , won't hurt a thing - but I would try my advice on the pto selector.Anyway, I'm considering offering $7,500 but am a little nervous about the PTO selector and whether it is a clutch linkage adjustment or if there is something more costly wrong with it. $8,500 is the top of my budget, I'm not sure I'll find one quite this clean elsewhere.
One more thing. Be sure to get the owners manual. If he doesn't have it dicker the price to go get one from Kubota. It is invaluable when it comes to servicing the machine.
What about WSM? normally its bought separately, but its awesome to have.
