Found an attachment for working over soft ground
   / Found an attachment for working over soft ground #1
bcp
Super Star Member
SW WA
Kubota BX2360
Found it here:
Farmal Cub forum
   / Found an attachment for working over soft ground #2
A tall man would not last long would he?:laughing:
James K0UA
   / Found an attachment for working over soft ground #3
I've got one of these going on the "Build-it-Yourself" forum. There are several problems with this design. Namely, his transmission and main rotor need to be at the center of gravity. His is too far aft. He's not going to have enough aft cyclic authority to get off the ground. Another problem with using the rear PTO for the transmission is you loose your PTO for other things. That is why I'm going with a mid-mount PTO transmission. I'm also going with coaxial rotors so I don't have to dedicate the 3pt to a tailboom and anti-torque rotor. What's the utility of having a flying tractor if you don't have a 3pt and PTO? May as well just be another helo sitting in the hangar (and I've got enough of those already). :confused:
   / Found an attachment for working over soft ground #5
Might work be useful on a hot day...
   / Found an attachment for working over soft ground #6
Using the mid-PTO is not a bad idea but watch the ratios in your 90* gearbox, at 2000 RPM that most mid-PTOs turn at comapared to the 540 you could burn one up pretty quickly. If you decide to stay with the 2000 RPM you'll likely exceed torque limitations of that mast and head fairly quickly.
   / Found an attachment for working over soft ground #7
"When Tractors Can Fly"; Just sayin'
   / Found an attachment for working over soft ground #9
I'd just utilize a jet engine tacked onto the 3 pt arms and load the rear tires with fuel for ballast....
ATLAS XAS110 COMPRESSOR (A52472)
ATLAS XAS110...
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
2015 Dodge Grand Caravan (A55758)
2015 Dodge Grand...
2017 FORD F550 XL SERVICE TRUCK (A51406)
2017 FORD F550 XL...
UNUSED LANDHONOR LHR-BLC9021 TOOL STOOL (A54757)
UNUSED LANDHONOR...
UNUSED LANDHONOR HPF-11-3000G HYD PALLET FORKS (A54757)
UNUSED LANDHONOR...
