Loading tires on a 4wd-two or four?
   / Loading tires on a 4wd-two or four? #1
nickel plate
CA
2002 New Holland TC40S
I just re-loaded all four R-1 tires on my 2002 NH TC-40/16LA FEL because I needed to drain one of the rears (lighter weight/safety removal and re-mount) for preparation of a new set of hydraulic rear remotes installation and in doing so, found out that plain water was the fluid of choice which was not disclosed to me when purchased new from the dealer.
Furthermore, one of the front tires had only air in the casing.:confused:
So let me ask this to the 4WD/FEL tractor owners; if and when you load your tires, do you just load the rears or also the fronts?
   / Loading tires on a 4wd-two or four? #2
if you've got a loader.. that seems like plenty of front ballast to me.. :) the few pounds the laoded front tires add are negligible compaired tot he weight of the loader.
   / Loading tires on a 4wd-two or four? #4
Plain water will probably work for you in California. Here in Michigan where we have a winter,I used windshield washer fluid. It was alot cheaper than having beetjuice put in them and it won't freeze.
   / Loading tires on a 4wd-two or four? #5
Do not load the fronts with a loader. My owners manual says that and it makes sense to me.
   / Loading tires on a 4wd-two or four? #6
I'd not!!
   / Loading tires on a 4wd-two or four? #7
I had all 4 loaded and haven't noticed any ill effect.
What make and model do you have and could you please quote/type what the manual actually says? I've scoured my two NH operator's manuals and find nothing mentioned about front tire fluid loading.
Either front or rear tires which are loaded produce no more amount of down force weight on the axles than tires just filled with air as the tractor axles ride centrally supported on the steel rims. Example: Two air filled tires standing alone and only connected by an axle. Sit on the axle (your body weight is acting as the tractor body). Get up, fill both tires and again sit on the axle-notice any weight difference by adding that extra several weight of fluid? Of course not. Your body weight is still the same in both conditions (unless you took a lunch break in-:licking:between).
Not so if I added suitcase weights on the front end. Every ounce of those weights will add down force weight and directly effect the performance of the front axle. I would have an issue with that setup if not actively supported by the tractor's manufacturer.
My primary reason for loading the front tires is to help acheive a lower center of gravity when working in my hill property.
   / Loading tires on a 4wd-two or four? #9
Front wheel lifting is common with a loader but I am sure there is a big difference in axle loading and four wheel drive if tires are weighted.
   / Loading tires on a 4wd-two or four? #10
I would load all 4. It helps support the weight when the loader is used at it's max capacity. Really cuts down on the tire bulge. If you are one of the few that removes your loader as I do when doing field work, it is really nice to have all the weight that you can get. I even doubled up on my front end weights. Having the additional weight up front has made a HUGE difference with how well the tractor does out in the field. ;)
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A51692)
2001 Sterling...
2021 Kubota KX033-4 (A53317)
2021 Kubota...
2016 Freightliner M2 106 Altec AM50 50ft. Bucket Truck (A55852)
2016 Freightliner...
2011 Ford F-350 Knapheide Service Truck (A54814)
2011 Ford F-350...
(2) Firestone 420/80R46 Tires w/Rims (A56469)
(2) Firestone...
2019 John Deere 8295R MFWD Tractor (A53485)
2019 John Deere...
