Buying Advice Ford 8N - Is it worth consideration?
   / Ford 8N - Is it worth consideration? #21
heck.. move up 3 ys and enjoy much of the stuff available today, live pto, live hyds, power steering.. etc.... move up 7 ys and you can get diesel, and independent pto.. etc...etc
   / Ford 8N - Is it worth consideration? #22
move up 7 years and get much more for your money!
   / Ford 8N - Is it worth consideration? #24
terrible ain't it.. :)
my newest tractor has had the most expensive problems... I remember when a deluxe hyd remote pack went out on my 2000 7610s.. cost over 700$ in hard parts.. plus some labor and oring kits.. could buy a intact parts tractor for that $ on an older one!
   / Ford 8N - Is it worth consideration? #25
In what year did live PTO become a feature on the majority of the Fords? In other words, if you were looking for one of these tractors today (134/172 cubic inch, pre 3-cyl tractors) would you find that most of them have the live PTO or that most came with the transmission PTO? Is it easier to find one with live PTO or the other way around, or are they about equal?:confused: Most of the NAA's, 600's, 2000's I have run into do not seem to have the live PTO, but maybe it's a regional thing.
   / Ford 8N - Is it worth consideration? #26
in 1955 er.. late 54, the 00 series came out.. 600, 700, 800, 900.
if the middle digit of the model id was a 6, it had a 5spd trans and a dual clutch / live pto.
thus a 660 860, 960, etc would be a live pto machine.
in the 2000 / 4 cyl models, if it left the factory with a 5spd, it ws a live pto.. 2000's were 63-64 and could have had independent pto with a 10spd powershift trans too ( SOS )
there was a dealer add in aftermarket pinion clutch that could be added to the N and nAA, either lever or hyd, via lever, that clutched the pinion couple tube and gave you pseudo live pto on the n/naa as you could clutch the drivetrain and leave pto running.. just don't stomp the foot clutch.
soundguy
   / Ford 8N - Is it worth consideration? #27
soundguy
Hey, thanks for the information. :thumbsup: Are the ones with the 6 in the middle digit considered rarer than the ones that are non-live pto?
Do the model numbers work the same for the 601's and also the 800/801's?
Would you say the live pto's are more common in the 800/801's/4000's than in the 134 cu inch engine jobs? Sorry for all the questions, but you seem to have a lot of the answers. Thanks.
   / Ford 8N - Is it worth consideration? #28
all things considered, the live clutch was more money than the plain 4 spd *4* or the non live 5 spd *5* so one could conclude that it is more rare. you see LOTS of *4* machines.
and yes.. the middle digits of 4/5/6 carry thru the 00/01 series. 01 added a few for the sos *71 and *81 as well as other middle digits for machines with special setups.. etc.
even rarer in the early units is power steering.. :)
most of my fords are the non live variety type.. IE.. *4* and *5*, thought I do have a 660 .. no power steering.. but do have an 850 with power steering.. :)
soundguy
   / Ford 8N - Is it worth consideration? #29
I think you would be happy with the 8n. The machine can be worth more if it has had tie-rods and things replaced on it. Brakes , clutch, paint can be expensive. If the owner has done these things they will have a good idea of the money involved. Some people appear stuborn on price, but if they know what they have invested in their tractor you could understand why. A friend just redid his grandmothers 9n which she had bought well used for 500.00 dollars 45 years ago. It has been used to mow and push snow. He would be ashamed to tell her what the paint cost for the red belly!
   / Ford 8N - Is it worth consideration? #30
Personally, I don't trust tractors or other machinery with "new paint" unless I have proof that it was properly restored inside and out by someone who knows what they are doing because there are too many botched rattle can restorations out there.
Think about it, Joe Blow gets out the pressure washer to clean off the accumulated gunk, then slaps on some "new paint" so he can jack up the price. No thanks.
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2007 INTERNATIONAL SF625 BUCKET TRUCK (A50854)
2007 INTERNATIONAL...
2016 LINK-BELT 235X3 SPIN ACE EXCAVATOR (A50854)
2016 LINK-BELT...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
2019 FORD F450 TOW TRUCK (A51222)
2019 FORD F450 TOW...
2019 RBR Venturi 380 (A51039)
2019 RBR Venturi...
