3 Cylinder Gas Industrial - Weak Hydraulics
   / 3 Cylinder Gas Industrial - Weak Hydraulics #1
deerfarmer239
fenton, MO
Ford
New member to the community!
Weak hydraulics on a John Deere 3 cylinder industrial gas tractor.
Part of the tag shows it as a NT4P maybe?????
I can't find the correct model # to investigate the problem.
Tractor is good for bush hogging and has a small loader bucket on it.
Any help with ID of the model or hydraulics would be helpful...
   / 3 Cylinder Gas Industrial - Weak Hydraulics #2
Welcome to TBN. :)
   / 3 Cylinder Gas Industrial - Weak Hydraulics #4
WELCOME to TBN :)
I moved your thread to the John Deere Ag Tractors Forum.
   / 3 Cylinder Gas Industrial - Weak Hydraulics #5
More than likely the model # is 1020 or 300 if it's a industrial model. How long since the hyd filter was changed and sump screen cleaned??
Not sure on the filter or sump. Assisting a friend with the tractor. I will ask him. Did find out that it is a John Deere 301 Industrial. Appears the 3 point is weak and sometimes won't work. When the loader is attached to the front he has to fuss with the controls to make it work. I suspect from what has been said that the sump and screen are dirty and a good place to start.
Thanks to all who have assisted!
   / 3 Cylinder Gas Industrial - Weak Hydraulics #7
With 3pt raised,engine running,look inside hyd oil filler hole for spraying oil which indicates leaking o-rings on 3pt control vales which adversely affects the operation of other hyd functions.
   / 3 Cylinder Gas Industrial - Weak Hydraulics #8
What kind of loader control valves? If the valves are open center , closed center with a blown seal or equipped with a relief valve set below 2300psi. The hydraulics will never work properly.
Thanks to all who have offered advice. I had to stay on a job out of country, so I have not been able to follow up as closely with the forum or the repair as I wanted. Now that I am home I hope to be able to assist my friend with the problem at hand. It will have to be a weekend trip though, as we are some distance apart.
From what we are told the system in closed center hydraulics.
Thanks again and I will keep posting as to what we find.
   / 3 Cylinder Gas Industrial - Weak Hydraulics #10
T
Yes the hyd's are closed-center. Depending on yr model the power steering could be open center supplied by a hyd pump bolted to RH frt of engine.
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
Quick Attach EZ Axe Skid Steer Tree Shear (A53473)
Quick Attach EZ...
Tires (A50322)
Tires (A50322)
2019 Chevrolet Tahoe SUV (A52377)
2019 Chevrolet...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2005 CHALLENGER 500 BBL FRAC TANK (A53843)
2005 CHALLENGER...
