I think my tail wheel is too big
/ I think my tail wheel is too big #61
It appears that the yoke stem is bent at the blue arrows. The orange arrow points to what also might be bent. If it was meant to be that way, wouldn't it be easier and less expensive to just grind an angle on the stem where it welds to the yoke plate?
The second photo is my Bush Hog Squealer 480. Slightly different design but note that the stem and yoke plate are built at 90 degrees to each other.
Your mower's tail wheel was in a collision.
/ I think my tail wheel is too big #63
I have enjoyed following this thread.
As usual, A LOT of good advice has been given to the OP's initial question.
What I find interesting is this. Here you have a simple question asked. This similar type question is asked by the hundreds over the course of a week on this board. However, most are lucky to get anywhere from 5-10 responses from all of the 1,000's of members on this board.
So, what is different about this post?
Why has this particular question gotten 60+ responses and climbing. It doesn't seem like the posts have slowed hardly at all.
Now, has the original poster yet said what course of action he is taking?
Great place for knowledge and entertainment.
Keep it up. :thumbsup:
/ I think my tail wheel is too big #64
IMO, pictures and prompt responses from the OP.
Aaron Z
/ I think my tail wheel is too big #65
IMO, pictures and prompt responses from the OP.Aaron Z
Very true.
Those 2 things always help when trying to offer advice or some course of action on this forum.
/ I think my tail wheel is too big #66
I could care less about the tail wheel assembly. Its hella expensive to replace.
There is a second set of bolt holes farther back on the mower deck that he could move the tail wheel arms to.
He would have to relocate the up/down adjustment for the tail wheel, but given the nature of most hobby farm people, that may be a much simpler and way cheeper fix than buying a new $100+ tail wheel assembly.
/ I think my tail wheel is too big #67
Certainly bent and, I would want a washer at the top for the pin to bear on...the variety of other pics posted of other designs illustrate the difference between "caster" and "kingpin alignment" IMHO.
The weld of the fork onto the (should-be-) vertical shaft seems like a refit and if there is some slop between that shaft and its tube, I'd suspect someone welded on an undersized shaft ...which has allowed it to be bent ...it should not be a sloppy fit but snug w. just some space for grease. This retrofit of the shaft would account for it extraordinary length (w. no other through holes for fastener)
/ I think my tail wheel is too big #68
The only problem with this tailwheel is a bad previous repair job. Someone has lengthened and stepped down the diameter of the shaft before the weld to the yoke. This is weak and has bent, resulting in the excessive caster and interference with the deck. Just get a new shaft/yoke unit with the same diam. shaft--should be less than $50. A Land Pride or Bush Hog one would probably work. It looks like the tube at the end of the arms is worn at the rear also. Fabricate a new one to the length required by the shaft/yoke unit you buy. Drill and tap a grease fitting and keep it lubricated. Don't try to salvage the messed up shaft/yoke by heating and straightening. It will be even weaker than before and will quickly bend, leaving you right back where you were.
/ I think my tail wheel is too big #69
Maybe its bent?:D
/ I think my tail wheel is too big #70
Does this bush hog make my tail wheel look big?
Sorry, couldn't resist... :D
/ I think my tail wheel is too big #72
So? is it fixed. I stand by my post #3 :). I was in a hurry and the posters behind me correctly stated that its the post the forked shaft is on that is bent. I will drink a beer to celebrate, or to admit I was wrong at 5 pm today:thumbsup: I would just like to know which I am drinking too:licking:
/ I think my tail wheel is too big #73
Yes, I to am wondering where this saga stands.
/ I think my tail wheel is too big #75
Post # 45 had a picture of a tailwheel just exactly like this one SHOULD be if if wasnt bent and modified with the larger shaft to fit the mower. A 10 minute fix with the correct material. Cut the old BENT up shaft off the tailwheel yoke, grind smooth, put on a new vertical shaft with the proper diameter to fit tightly in the bushing part and proper slant and fillet weld to the yoke. DONE DEAL. I could have fixed it and had it painted by time the 5th post was made on here.
/ I think my tail wheel is too big #76
:laughing::laughing::laughing: I've never had a 10-minute job take less than 2 hours - especially if it involves welding/cutting/grinding.:D
/ I think my tail wheel is too big #77
Yep...and with me, normally two trips to the local Ace Hardware.
I wonder how the OP made out?
2015 Chevrolet Silverado 3500HD Knapheide Enclosed Service Truck (A59230)
2015 Chevrolet...
2011 Kubota KX080-3 Midi Excavator (A59228)
2011 Kubota...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
1997 DORSEY AIDT-LSCG 53 FT DRY VAN TRAILER (A59905)
1997 DORSEY...
2014 Ford Flex SUV (A59231)
2014 Ford Flex SUV...
