Looking into a 2 bottom Dearborn disk
   / Looking into a 2 bottom Dearborn disk
Okay, the Dearborn is pushing my tail end to the left. Are there any adjustments, or do I need to take a smaller bite?
Oh yea, here is a couple of pix.
   / Looking into a 2 bottom Dearborn disk #13
Put a 6 inch block under your 2 left tractor tires, adjust the plow to run level with the ground front to back with your top link and level with the ground right to left with your tractor leveling arm crank on the right rear. After you make a furrow, fine tune adjust the plow in the same way (just wont need the blocks under the left side) The front disc should be taking about 12 inches. Spacing on the tractor tires should be pretty close to 24 inches from the center of the draw bar to the right rear tire inside rubber. If not close to that, adjust the track width of the tractor or slide the plow some on the cross draw bar to reconcile. Ken Sweet
Thanks, I'll try in the morning.
Okay, after adjusting the lifting arms to the middle hole I can now move around without dragging any. I noticed that one pin is dog legged and the other is straight. I am thinking that this controls the bite. If I roll the pin forward, I should get a smaller bite. A Smaller bite means less crabbing. Let me know if I am wrong, or make suggestions as needed.
Carl
   / Looking into a 2 bottom Dearborn disk #16
Carl
The rotating adjustable cross drawbar is only for making the plow follow in a straight line with the center line of the tractor and not a angle "off" the center line of the tractor. To get width of cut on the front plow can only be accomplished by the earlier setup described last night. Ken Sweet
Wish I had seen this earlier. I have one in Madisonville I would have sold for a lot less than that. You will like it
Do you still have this? If so PM me. Thanks
Carl
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
MOBILITY SYSTEMS REFRIGERATOR CONTAINER (A56129)
MOBILITY SYSTEMS...
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
Year: 1990 Make: Ford Model: F-450 Vehicle Type: Pickup Truck Mileage:44780 Plate: Body Type: 2 D... (A55852)
Year: 1990 Make...
2024 Cynergy Cargo 2 Enclosed Trailer (A53117)
2024 Cynergy Cargo...
