2210 Transmission
   / 2210 Transmission
don't rule out the trans just yet, it still could be the MFWD drive gears/shafts in the trans that are bad. have someone els drive it and have a look and see it the front driveshaft is turning while moving.
I will check that tomorrow...
So in 4wd if the front driveshaft is moving (that is a good thing) but still experience no reverse then it is the front axle.
But, if in 4wd the front driveshaft is NOT moving then that is a bad thing indicating that it is 4wd linkage in the transmission..
Correct?
As you can tell I am not a motor head and need to keep it simple!
Mike
   / 2210 Transmission #12
Correct?
Mike
if the front DS is turning it is NOT the front axle and the problem is in the transmission.
if it is not turning then it IS the axle.
it might be easier to jack up the frontend and turn both front wheels in both directions(fwd/rev) and see if the DS turns. also while it is up put it back in 4wd and try to turn the front wheels and see if you can. With it in 4wd you should not be able to turn the front wheels.
   / 2210 Transmission #13
Hi Mike,
very curious if there is something gone bad in the front axle. maybe it's just one little gear (most of them just $30-$50) and John Deere will give you a quote of a whole new component ( like differential $875, final drive $400) and to get to it they would charge you all the hours. If you would trade it in they quote you the whole deal and they just put a new little piece in and making big $$ selling it. a bigger tractor would be very helpful on your sloped ground, but me being a mom I pulled the whole front axle apart, so if you want to get your hands dirty you can do this too. Although you might not have the knowledge what really was bad you could pull the front axle from underneath and start unbolting the big pieces and bring those pieces to JD. By doing this yourself, I think this you would already save a ton. Since I have to put today my front axle back together i will make some pics in case you need them. Just let me know if it is something in the front and I will walk you through it. ( privately).
   / 2210 Transmission
Hi Mike,
very curious if there is something gone bad in the front axle. maybe it's just one little gear (most of them just $30-$50) and John Deere will give you a quote of a whole new component ( like differential $875, final drive $400) and to get to it they would charge you all the hours. If you would trade it in they quote you the whole deal and they just put a new little piece in and making big $$ selling it. a bigger tractor would be very helpful on your sloped ground, but me being a mom I pulled the whole front axle apart, so if you want to get your hands dirty you can do this too. Although you might not have the knowledge what really was bad you could pull the front axle from underneath and start unbolting the big pieces and bring those pieces to JD. By doing this yourself, I think this you would already save a ton. Since I have to put today my front axle back together i will make some pics in case you need them. Just let me know if it is something in the front and I will walk you through it. ( privately).[/QUOTE>
Ok Gentlemen, I think we have it pinpointed to the Tranny...
In 2WD everything works, works well, forward and reverse, FEL and MMM and the HST holds the tractor on inclines as it should.
In 4WD I have forward but no reverse, FEL and MMM work no problem, and the HST behaves like it's in 2WD.
Further Testing:
I used my bucket to raise the front wheels off the ground and found the following:
In 2WD:
In neutral Drive Shaft turns freely when front wheels are turned manually.
In lo gear drive Shaft turns freely when front wheels are turned manually.
Both conditions as to be expected.
In 4WD:
In neutral Drive Shaft turns freely when the front wheels turn freely and are NOT locked!
In lo gear drive shaft does NOT turn and front wheels do NOT turn when trying to move forward. Also front wheels turn freely when manually turned!!!! The tranny is not locking the Front Drive Shaft and Front Wheels.
So, the problem appears to be the 4WD linkage in the transmission! ****!
After Action Report:
After a fair amount of investigation I can only deduce the following which resulted in said "wild ride" with 2210 doing a wheelie:
I was mowing the turf in 4WD & Lo Gear going up the hill in reverse as I have for 8 years when the 4WD linkage or rod in the tranny got disconnected, broke, or something.
This resulted in the front wheels being "free wheeling", essentially turning the tractor into 2WD and I didn't know it... The broken/failed linkage was also preventing me from going in reverse, jamming something.
(In the 8 years that I have had the 2210 I don't think it has been in 2WD more than the very few times I found it to be life threatening to be in that mode...)
When I put the transmission into neutral and then back into lo gear and began a forward descent speed began to pick up and the rear wheels couldn't hold it just by themselves - too much weight with a 35 degree incline.. remember, my 2210 has foam filled front and rear tires which signifcantly add to the weight of the machine....
When I tried to apply the brakes the machine had too much downward momentum with the weight and began to slide, all the while gaining more momentum....
So gentlemen, I think that this is the best I can do in troubleshooting where the problem is and in trying to determine cost....
Best Case Scenario: Tranny has to come off, at best MFWD 4WD linkage gets put back on or replaced.
Anyone have a best case scenario cost estimate? Besides big bucks?
I think I may invest in a trailer hitch and rent a trailer to make the 2210 mobile which would save me $200. in having the dealer do a pickup/dropoff AND maybe I can get it to another JD dealer for a second opinion...
Do you gentlemen agree with the assessment and next steps?
Thanks again,
Mike
   / 2210 Transmission #15
If you don't have account with JD and you don't have pricelist go to dowdatractor.com they have all pics and prices with it. If you live rural get in touch with a farmer. They always know some handy guys and might love to work for you and probably have equipment to haul to. Try to post a "help" on the big JD tractor forums, mentioning your location and see if anybody can pinpoint what you need to have fixed or they know someone...Walk into transmission shop and just ask what's wrong with the knowledge you have now. Wait for more answers on this forum. I would try to avoid JD dealer. Wish you lots of luck. Sorry I can't help you more.
   / 2210 Transmission #16
No one, not even the dealers' mechanics, will be able to estimate a cost figure until the actual problem is known.
They can give you hauling costs, estimate the tractor splitting costs (as you say you know it is in the tranny), and add up the replacement of fluids. But beyond that, they don't have a crystal ball and will somewhat have to play it by ear at so much an hour.
Myself, I'd go to my dealer and hold my breath. Your time and interest in doing it yourself or going elsewhere to try cheaper will have to be your call.
The Deere mechanics that I know at my dealer are great guys and trustworthy. The ones that I've known over the past 15 years there that were on the sneaky side didn't last very long. The good ones don't want to hear that they didn't solve the problem and have the job come back for re-work. Nor did the owner of the dealership want to hear such things either.
However, they also know if someone is playing one dealer against another for low-ball price. They are more fair to a customer who is a good customer and likely to continue to be a customer. Just common sense to cultivate good customers and treat them good so they will come back. They don't get gov't subsidies to operate their business like so many of us see happening nowadays. ;)
This isn't meant to be a lecture as you are free to do what you want, but just a reminder that we have expensive machines and they will break down on occasion. It takes money to have someone else do the work for us, when we can't/won't do it ourselves.
   / 2210 Transmission
This isn't meant to be a lecture as you are free to do what you want, but just a reminder .
I'm shocked, just shocked that you hate capitalism so much and the American Way! Just Shocked! :confused2:
I truly didn't think from the tone of the email that you were one of them liberal progressive left-wing commie-loving pinko free-market-hating "down with competition" flag-burning 99 percenters ! :laughing:
I'm with YOU! I think we should have fixed prices for gasoline, groceries, for everything! If I go to a 7/11 I want to pay the exact same price for a bag of chips or a gallon of unleaded that I would pay at any other convenience store or gas station!
I Agree! Lack of competition and monopolistic practices is the way we roll Mister! We're Americans, proud of it, and that's how we like it!
:thumbsup:
   / 2210 Transmission #18
Mike,
Not to change the subject or turn the discussion, but I figure with your type of usage with a 2210 you'd be the perfect one to ask. Did you ever have a problem with the u-joints on the driveshaft? Many have had problems with them around the 400 hour mark, mostly because of the nearly impossible task of greasing them. Just wondering if you ever had a problem with them and if you greased them or not.
   / 2210 Transmission
Mike,
Jim,
I think the 2210 has sealed driveshaft U-joints. When I was under it the other day I made a specific point to see if there were any grease fittings and I didnt see any.
If the U-joint is make squeaking noises it may have to be replaced, and that is the LAST thing you want to break especially if you are on an incline and counting on the 4WD/HST/Lo Gear to keep you from having a wild ride down!
However since we are on ths subject make sure that you put grease into the front differential whenever you greast the front suspensions ball joints - which should be often.
I am just hoping that fixing the 4WD trasmission linkage isn't going to be too costly - I REALLY liked the 2210 and would get another one.
In looking at the 2305 I liked that as well as it addressed a few mechanical issues that I found inconvenient with the 2210, but other than that I think I would get a 2305 as well... And still may consider that since I do not like the 1023/1026 and want to stay Green.
Mike
   / 2210 Transmission #20
Mike,
That's reassuring that you haven't had any problems with the u-joints. It sounds like you have the sealed joints, where mine have grease fittings. You can see them, but nearly have to take the tractor apart to get at them (which I haven't been able to get at :mur:) . From what I understand, some had fittings while others didn't. I spoke with my dealer who said that they haven't had any problems with owners coming in to have the joints replaced and were unaware of any issues. I figured with the stress that your terrain must put on them I was curious if you ever had an issue or if you had any particular maintenance routine for them.
I also hope that your issue is resolved with minimal cost & headaches. The 2210 is a great machine & like you, hope to get many years out of it. Certainly keep us posted!
Skid Steer Concrete Mixing Bucket (New/Unused) (A59225)
Skid Steer...
2013 Cummins DSGAB 125kW Standby Diesel Generator (A56857)
2013 Cummins DSGAB...
2015 Freightliner M2 106 AWD Terex Commander 4047 Digger Derrick Truck (A55973)
2015 Freightliner...
Terms & Conditions of Auction (Payment Terms) (A59213)
Terms & Conditions...
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
