Cultipacker design question.
   / Cultipacker design question. #1
HCJtractor
upstate South Carolina, Greenville
Kubota M6800, Massey Ferguson 240
I am designing and building a cultipacker using the packer wheels from Everything Attachments. It will be 88" wide using 22 wheels weighing 28 lbs. apiece for a total of 616 lbs. The shaft is cold rolled 2". It will be a lift style with hydraulic wheels to lift the whole assembly up off the ground for ease of transport. My question is whether I should add a center support and bearing to help support the weight when lifted to prevent bending or bowing of the shaft. It would add a gap in coverage, but that's no big deal as far as I can see. I just don't want to damage the shaft when it is bouncing during transporting. Would you add a third bearing or should 2" shaft be rigid enough??
   / Cultipacker design question. #2
What's the wall thickness on the 2" dia shaft? I'd go 1/4" thick and not worry about bending with only 616 lb. But it's easy enough to added a central support bushing so do that if you're still worried.
Good luck.
   / Cultipacker design question. #3
HCJtractor
I'm assuming the 2" is solid bar ? then with the 3 point in the air and the bar pulled o/c is supporting about 300 lbs on the tips? I think your ok ...say if you added more weight in the future to it.Then do your physics
ak9
   / Cultipacker design question. #4
It would be easier to add the center bearing now than later.
Thats a big span unsupported and will flex quite a bit both transporting and in use.
Yes, the shaft is a solid shaft. I don,t think I have ever seen a packer with a center bearing. Have you guys?
   / Cultipacker design question. #6
I have always assumed that they are designed without a center support because they need to flex a little bit to conform to the ground contour? What do you all think?
Oldstuff
   / Cultipacker design question. #7
If I were building a cultipacker, I would be sure the rollers were cast in the USA. I hear horror stories much too often about imported rollers cracking and busting after a short time. A new Brillion 18 inch USA cast roller should cost around $70 each.
Herein lies the problem. At $70 each, a seven footer would be over 2 grand just in rollers. That's really not feasible for most of us. Even so, I don't know anyone in this area who could even get the Brillion, although I agree they are the mac-daddy cultipackers. The only other rollers I have seen are those little 9 inches from Agri Supply, and those appear to be the ones most use. These 15" ones from Everything Attachments appear to be pretty solid, but I have no idea where they are made. The only other source is to buy used, and they are very rare around here. I know you sell them and I actually bought a set of crow foot rollers from you last year, and frankly was rather disappointed, so they are still sitting in my shop unused. Because of that experience, I won't buy any more used rollers sight unseen.
   / Cultipacker design question. #9
2" is a big shaft but you are right to question whether you should add a center bearing at 88" long. Quick calcs using a 10G shock load show that you should have no problem with the 2" solid shaft. It still seems like a long span though so I am wondering if my 10 G assumption is good. As for flex in the field under at 1G - don't expect any. If it were me I would still put in the center bearing.
   / Cultipacker design question. #10
I would add the center support. It is easy to do it now while building the cultipacker. You might also want to buy a receiver hitch tube and weld it on the opposite side of the cultipacker. If you deceide later you want to pull the cultipacker rather than lift it with the 3 pt. Then you just slide in a 2x2 sq steel tube to make a trailer tounge and hitch.
something like this:
OMNI 60 Inch Cultipacker - OMNI Mfg LLC
1978 Gray 48RM Vertical Boring Machine (A59213)
1978 Gray 48RM...
2006 CATERPILLAR 304C (A58214)
2006 CATERPILLAR...
2012 DRAGON 130BBL VAC TRAILER (A58214)
2012 DRAGON 130BBL...
CATERPILLAR 255 SKID STEER (A60429)
CATERPILLAR 255...
PJ  32 FLATBED GOOSENECK (A58214)
PJ 32 FLATBED...
UNUSED FUTURE HYD AUGER (A52706)
UNUSED FUTURE HYD...
