Size of Fertilizer
   / Size of Fertilizer #1
Agrantina
West Tennessee
Kubota L3240 GST
Bought a new 3pt spreader the other day at it has the settings listed by large, med, small granular fertilizer . Big difference in the setting per size..
My question is what size is 15-15-15 co-op brand???? Never seen it listed by size??
AndyG
   / Size of Fertilizer #2
Thats a new one on me too! I use 10-10-10 for most applications and also pelltized lime.
Pelletized lime in my opinion is "small" granules maybe .080" and 10-10-10 is medium granule size .100 to .125". Then you have specialty treatments like for Grubs that are a very small granule about .050".
I would experiment with small and medium settings personally.
The other question is what does this regulate? The opening for the spreader?
   / Size of Fertilizer #3
Is that what is in the book or on the unit itself on the control mechanism? Usually it has numbers on the spreader up to 7 or 8.
15-15-15 is granular fertilizer. Just like triple 13 or 19.
You are looking at about 300# per acre at setting 4 at 5mph if I recall correctly.
Small, medium and larger generally refers to seed size.
Hope this helps.
Hope this helps.
both the book and on the spreader.. It has --example setting 2 at 4.5mph is about 110lb ac.. that is with medium size.. With small - same setting is about 320lb per ac.... I am going to test first but just have never seen a size chart for fertilzer?
AndyG
   / Size of Fertilizer #5
How many pounds per acre do you want?
   / Size of Fertilizer #7
Set the opening at about 1/3 open, do 5 mph and let it rip. That's what I'd do. You could start with 50# and see if that spreads like you want it.
(9) ROLLS OF 5' - 10 GAUGE CONCRETE WIRE (A54757)
(9) ROLLS OF 5' -...
2008 Genie S-65 65ft Telescoping Boom Lift (A53421)
2008 Genie S-65...
2007 INTERNATIONAL 4300 SBA 4X2 DUMP TRUCK (A51406)
2007 INTERNATIONAL...
2008 Ford F-550 4x4 Dump Truck with Lift Gate (A53422)
2008 Ford F-550...
1984 Gleaner A630 Corn Head (Deutz-Allis branded) (A55301)
1984 Gleaner A630...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
