Size of Fertilizer
   / Size of Fertilizer #1
Agrantina
Platinum Member
West Tennessee
Kubota L3240 GST
Bought a new 3pt spreader the other day at it has the settings listed by large, med, small granular fertilizer . Big difference in the setting per size..
My question is what size is 15-15-15 co-op brand???? Never seen it listed by size??
AndyG
   / Size of Fertilizer #2
Thats a new one on me too! I use 10-10-10 for most applications and also pelltized lime.
Pelletized lime in my opinion is "small" granules maybe .080" and 10-10-10 is medium granule size .100 to .125". Then you have specialty treatments like for Grubs that are a very small granule about .050".
I would experiment with small and medium settings personally.
The other question is what does this regulate? The opening for the spreader?
   / Size of Fertilizer #3
Is that what is in the book or on the unit itself on the control mechanism? Usually it has numbers on the spreader up to 7 or 8.
15-15-15 is granular fertilizer. Just like triple 13 or 19.
You are looking at about 300# per acre at setting 4 at 5mph if I recall correctly.
Small, medium and larger generally refers to seed size.
Hope this helps.
Hope this helps.
both the book and on the spreader.. It has --example setting 2 at 4.5mph is about 110lb ac.. that is with medium size.. With small - same setting is about 320lb per ac.... I am going to test first but just have never seen a size chart for fertilzer?
AndyG
   / Size of Fertilizer #5
How many pounds per acre do you want?
   / Size of Fertilizer #7
Set the opening at about 1/3 open, do 5 mph and let it rip. That's what I'd do. You could start with 50# and see if that spreads like you want it.
2018 Dodge Grand Caravan SXT Van (A55758)
2018 Dodge Grand...
2025 78in Rock Bucket Skid Steer Attachment (A53421)
2025 78in Rock...
2019 Ford F-550 4x4 Altec AT40G 40ft Bucket Truck (A55788)
2019 Ford F-550...
John Dozer JD650 (A51691)
John Dozer JD650...
UNUSED JCT 2 PRONG BALE SPEAR (A54757)
UNUSED JCT 2 PRONG...
