Craftsman 18 hp hard to turn over?
   / Craftsman 18 hp hard to turn over? #1
300UGUY
Super Member
Howell, Michigan
Kubota L3400, Farmall H
I have a problem with a Craftsman mower with a B&S 18 hp motor. I put a new solenoid and starter on, it doesnt want to start. It turns over very slowly. Plenty of oil, but the battery is dead. I have been trying to jump start it with a battery charger. Is the engine simply shot? I really don't understand why it doesn't start.
   / Craftsman 18 hp hard to turn over? #2
Do you have one cylinder or two. Does it start to turn over and then stop, and maybe sometimes tries to kick back. Could need the valve clearances adjusted. Compression release on camshaft could be broke, lower likelihood though.
It's a twin, I pulled both plugs, it seemed to be a little stiff, but I could turn it with one hand on the wrench. It turns very slowly, only moveing a little bit. The starter makes a bunch of noise, it seems like it is trying, but it can't get it turning. I know it sounds weird, but I am thinking of replacing the battery, maybe it is shorted internally, or ???
   / Craftsman 18 hp hard to turn over? #5
Sounds like you need to rebuild starter
   / Craftsman 18 hp hard to turn over? #7
I would disconnect the dead tractor battery and jump it directly from your car battery.
   / Craftsman 18 hp hard to turn over? #8
Fought that problem for years, valve adjustment. believe it or not. Swapped out batteries, starter solenoids, and starters. (still have a new one in the box, they don't take them back) Adjust the valves, and adjust them next year too. A new fresh battery may make it roll over, and your starter solenoid may be burnt now, from the excessive starter current drawn trying to break the engine over top dead center. And replacing that may make it start, but the root problem remains, valve timing and operation of the compression release mechanism. Known Briggs OHV problem.
James K0UA
   / Craftsman 18 hp hard to turn over? #9
99% of hard starting on B&S ohv engines is valve adjustment, you can do it in 30 minutes the first time and 15 the next, very simple.;)
   / Craftsman 18 hp hard to turn over? #10
Is your engine an OHV engine which has easily adjustable valve or the old L head engine which does not?
This one must be the old one, the valve is in the block. I took the plugs out, it doesn't seem to be a compression problem. It didn't turn over very well. I have a new starter and solenoid, and I am using a battery charger to turn it over. It should be really spinning. I am debating what to do next - junk it, pay somebody to rebuild the motor, or ??
   / Craftsman 18 hp hard to turn over? #12
Like Dana Warner said, jump start it from a vehicle. Try it without plugs. Don't burn out your starter.
   / Craftsman 18 hp hard to turn over? #13
I'm sure others will disagree with me but battery chargers are not designed to be used in place of a battery. If you want to test the operation of your starter you should be jumping the starter from a good battery. Even a bad battery can cause you to have starter symptoms. I would suggest you remove your bad battery from the circuit and jump directly from a good battery. The battery charger is ok to be used as a boost on a weak battery but should not be used in place of a battery.
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
Honda EM3800SX Portable Gasoline Generator (A59228)
Honda EM3800SX...
Kubota M108S (A53317)
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 94,452 Plate: Body (A59230)
Year: 2014 Make...
2015 CATERPILLAR 308E2 CR EXCAVATOR (A60429)
2015 CATERPILLAR...
S/A Fuel Tank Trailer (A59231)
S/A Fuel Tank...
