ford 1720 brake shoes
   / ford 1720 brake shoes #1
double hunter
Gold Member
Ford 1715
Does anyone know where I can get after market brakes shoes for a Ford 1720 tractor.
   / ford 1720 brake shoes #2
They are a low production specialty shoe so you are not going to find an aftermarket source like for a pickup or car. So they tend to be real expensive from the dealer. Here are some suggestions:
eBay. They come up now and then although not really cheap either.
Find a brake rebuilder in the area. A lot of commercial and industrial equipment get the shoes rebuilt by an independent shop that will mount up linings onto shoes by riveting or bonding.
Mount your own. It's what I did and has worked out well with the only issue being a lot of adjustment until the shoes wear into the correct radius.
Use google to search for: " TooManyToys facebook " then look in my photo albums for the relining of my 1710.
   / ford 1720 brake shoes #3
   / ford 1720 brake shoes #4
This site is amazing for it's buddy hi-fives.
Just popped the cover off the brakes, this tractor has disc brakes and if it doesn't run in oil Iv'e got one heck of a leak, quite a bit pf oil in the shop before I could recover a bucket. if anyone has repaired the brakes on this model I would appreciate any info, thanks in advance.
Just a little FYI, these brakes do run in oil, they are disc brakes, available thru New Holland and aftermarket, takes 3 per side, only adj is the linkage, same disc on several different models,
   / ford 1720 brake shoes #7
That's good to know. NH website was down and I was not able to see if brakes were dry or wet.
JC,
   / ford 1720 brake shoes #9
it is certainly good to have a benevolent overseer to keep us all in check.
it is a fact that " you don't know what you don't you " but more so, it is a shame just to accept it and not want to find out.
Got the parts in today, easiest brake job I ever did, saide the old disc off and slide the new ones on palce, takes longer to scrape off the old gasket than anything else, just slightly expensive,
49" X 74" EXPANDED METAL RAMP GATE (A51247)
49" X 74" EXPANDED...
2006 GREAT DANE 48FT FLATBED TRAILER (A53426)
2006 GREAT DANE...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2022 John Deere 333G Track Loader (A53342)
2022 John Deere...
