Wheel bearing repack ?
   / Wheel bearing repack ? #1
redka
Middle GA
Few months back I bought a JD model B grain drill, cleaned it greased all the fittings, replaced a few things, and used it once, and it did fine. I figured I better pull and check the wheel bearings. With the help of some threads on here and the owner's manual, I got them out, cleaned up, reg-greased and put back together okay.
I'll be using the drill about three hours per year. How long before it will need the wheel bearings cleaned/re-greased again? Thanks
   / Wheel bearing repack ? #2
Most likely will last the rest of your life. How old are you now?
UNUSED JCT 84" HYD GRAPPLE BUCKET (A54757)
UNUSED JCT 84" HYD...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
TORO TRX-20 WALK BEHIND TRENCHER (A51406)
TORO TRX-20 WALK...
2012 BMW 328i Sedan (A53424)
2012 BMW 328i...
Butterfly Artwork (A55758)
Butterfly Artwork...
2016 Ford Taurus AWD Sedan (A55758)
2016 Ford Taurus...
