Wheel bearing repack ?
   / Wheel bearing repack ? #1
redka
Middle GA
Few months back I bought a JD model B grain drill, cleaned it greased all the fittings, replaced a few things, and used it once, and it did fine. I figured I better pull and check the wheel bearings. With the help of some threads on here and the owner's manual, I got them out, cleaned up, reg-greased and put back together okay.
I'll be using the drill about three hours per year. How long before it will need the wheel bearings cleaned/re-greased again? Thanks
   / Wheel bearing repack ? #2
Most likely will last the rest of your life. How old are you now?
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
Butterfly Artwork (A55758)
Butterfly Artwork...
202480 (A54757)
202480 (A54757)
2013 Ford Edge (A54815)
2013 Ford Edge...
ASSORTED BINS (A55745)
2003 INTERNATIONAL 9200I TANDEM AXLE DAY CAB (A56129)
2003 INTERNATIONAL...
