Entryway/Gate project
   / Entryway/Gate project #1
Dishpointer
Kansas
Ford 1600, Kubota F2690
My father started this entryway about 3 years ago with future plans on adding a gate down the road. He said he wants to tighten up security. Since I have free time at the moment (between new job) we decided to finish the project. This entryway will have 6 foot pillars next to the drive with a sloping wall that slopes down and curves to a smaller 4 foot pillar on the ends. He wants 2 automatic gates with a keypad/intercom that is tied to the phone so when someone pulls up and doesn't know the code or have a wireless transmitter, the call button rings the house phone and a command can be given to open up the gate. The openers will probably be from Chamberlain but definitely not a Mighty Mule.
The pillars and curved wall will be sitting on a 26" deep reinforced footer and will be made of block then brick faced. I have laid blocks before but we will end up subbing out the brick work as that is something we have never done before. I have talked to a few masonry guys and will place the brick ties in the block wall as per their recommendations.
This is the entry area. The road is about 25 yards behind where the picture was taken. The intercom will be to the left. The 2 steel I-beams are 4 foot in the ground with concrete and will be 6 foot above the footer. We will build the pillar around this and will attach the gate (weld the hinges) to this. The gates shouldn't sag at all!
This is leaving the property. The blocks we plan to use are stacked on the right.
The footing was dug by hand. Man it would have been nice to have a mini excavator! The first footing was down hill so in order to make both sides level with each other, we had to add forms and backfill. The other footer was higher up so we will use the earth as a form. We placed rebar every 14" and tied everything together and added wire to fill in the gaps as we didn't want to spend a fortune on rebar.
We were all ready to order concrete for Tuesday when the sky let out 3" of rain yesterday. We had to pump out the "trenches" and will have to fix the form in one spot where the rain washed out the dirt backfill.
We're not suppose to have rain for the next 7 days so we will let it dry out more and pour the footing on Wednesday. We will also place rebar into the concrete to tie the block wall to the footer. We will probably add rebar every 3 feet and fill that blocks cavity for strength.
More to come later.
Doug
Poured the concrete today and placed rebar to tie the wall in and it took 9 yards. Glad I didn't have to mix all 450 bags. (We got a truck)
Tomorrow we are getting ready for another 11 yards for the low-water bridge down by the creek. We bought corral panels that are 4' x 15' and the wire is as thick as a pencil, to reinforce the concrete. We used the extra yard of concrete today to reinforce the rocks and culvert that is in the creek. We are trying to get this done before the AG equipment comes to plant beans. I'll post pictures of tomorrows progress.
We got the coral panels all wired up and will pour 10 yards of concrete on Friday. We used rocks as spacers to keep the panels about midway in the concrete. We are going to use concrete come-alongs to pull the concrete into place. We won't float the pad as it will only be for equipment to access the other field. The only thing we need to worry about is that there are no low spots that hold water. The cross-over is 30' X 22' X 5"
   / Entryway/Gate project #4
Thanks for the pictures
It doesn't seem like anyone is interested in this project by the looks of the replies so I guess this will be my last update.
   / Entryway/Gate project #6
Hey now, that's a bit rash!
I think most of us appreciate the pictures and descriptions, even if there's not a whole lot to comment on. There's always more comments once you finish a project, too.
Nice job on those curved forms.
Thanks Deezler. I'll keep posting my progress then if there's an interest. Tomorrow I get the lovely task of pouring and spreading 11 yards of concrete at the low-water crossing. I started a dry run of blocks for the entry way so I'll post pictures later tonight.
   / Entryway/Gate project #8
First time I've seen this thread. That looks like one seriously substantial gate! Are you trying to keep someone out or....in? haha
It's a project that's been on the back burner for a few years and since I'm in between jobs it's a good time to get started. It will increase the value of the house while tightening security.
   / Entryway/Gate project #10
I am looking to make a security gate so please keep the pictures coming.
2021 Ford F750 (A50120)
2021 Ford F750...
2018 Ford Fusion Hybrid Sedan (A50324)
2018 Ford Fusion...
Air Reel (A50774)
Air Reel (A50774)
2008 Genie S-65 65ft Telescoping Boom Lift (A50322)
2008 Genie S-65...
New Holland 479 Haybine (A50774)
New Holland 479...
