Rotary cutter options, driveline, tailwheel and guarding
   / Rotary cutter options, driveline, tailwheel and guarding #11
Sorry, Soundguy... the LandPride design is just plain weak. I had an old Bush Hog LIGHT DUTY model with a mono-Uchannel tailwheel mount and good welds with never a problem. In addition, the fork design is super weak--just a single flat bar bent in two places. I've broken/bent several of them, and I'm not that hard on stuff. If you go with LandPride and cut anything other than flat, clean land, you're going to have to do some reinforcing yourself and have some spares on hand, or you're not going to be in the field for very long.
   / Rotary cutter options, driveline, tailwheel and guarding #12
My rotary mower is equipped with a slip clutch, laminated wheel, and chain guards - front and back. In regards to the guards, if you don't want to pay the additional costs, there are threads and posts here on TBN where some members have constructed their own guards - both rubber and chain type. Another factor that I considered before I purchased my rotary mower, was the gauge of the metal. Just a thought? Best wishes.
   / Rotary cutter options, driveline, tailwheel and guarding #13
Sorry, Soundguy... the LandPride design is just plain weak. .
...and if you use it like a bulldozer, and back into tree's and rocks it will be damaged. how am I not surprised here.. ;)
   / Rotary cutter options, driveline, tailwheel and guarding #14
Well, what can I say....? My land has old, harvested/deadfall trees, hidden by underbrush and saplings. If you're backing into this (even carefully--not bulldozing), you're eventually going to hit a trunk or a stump and put the tailwheel under stress. Every design on the market has its strengths and weaknesses. The LandPride machine has a good quality, heavy-gauge deck and good reinforcing. The hitch mounts are very strong and robust. The tailwheel mount, however, is weak. If a forum member is going to do some of the same work as I do, they might profit from making the tailwheel design a consideration, or planning to add some reinforcement, and adding a little slack to the sway chains to give some warning. Compare the difference between the LandPride design (right) and the older Bush Hog design, which I previously had.
   / Rotary cutter options, driveline, tailwheel and guarding #15
I have the Land Pride RCR26 Series and have smacked the heck out of stuff without any damage, but it is a different design than the others.
   / Rotary cutter options, driveline, tailwheel and guarding #16
i look at it like this. if backing my tractor an implement into a solid object.. I want the cheapest thing to break.. tail wheel mount is EZ to fix or make new... ( BTDT ) didn't take long.. nor was it hard... I don't want my 3pt pins on my trumpets to break off.. and I don't want my aframe to fold as they are harder to make right. and i don't want the deck to buckle.. some of the more economy units are just folded sheet metal anyway.
soundguy
   / Rotary cutter options, driveline, tailwheel and guarding #17
I have a Bush Hog Squealer 172, shear bolts, laminated wheel, and rubber guards. Mine is a medium duty cutter up to 2" diameter so I don't try to cut anything bigger and I rarely break a bolt, maybe 1 a year when my wife forgets the order of engage PTO then throttle up. What can you do? :confused3: After you clear your property of heavy stuff the grass and weeds should not shear bolts.
Like Soundguy said if you back into stuff like a tank something is going to give. If I am concerned I walk the area looking for hidden obstructions. If it is more than a 2" sapling that's why they make chainsaws. I use my equipment but do not abuse it. I would rather hire my dozer guy to clear a large parcel of land instead of tearing up my tractor and cutter. He is faster and makes a cleaner area by taking out the stumps instead of cutting them.
   / Rotary cutter options, driveline, tailwheel and guarding #18
There is no question that the LP tailwheel design is less stout than many of the others. Is it strong enough? That depends on the property and the operator, I guess, but the LP could be signifigantly reinforced without adding too much weight. And out back that far, weight would be a consideration for me. A couple of triangular gussets between the arms, with a few holes to lighten the load should do it fine.
   / Rotary cutter options, driveline, tailwheel and guarding #19
There is no question that the LP tailwheel design is less stout than many of the others. .
The OP is looking at a cutter is specifically a light duty cutter, possibly to match PTO HP. Land Pride uses the first number to designate whether it is designed for light - 1, medium - 2 or heavy -3 duty use. If you want something beefier you have to step up to a 2 or 3 series.
From the LP website: The RCR18 Series Rotary Cutters are available in 60" & 72" widths for light-duty maintenance around the farm, on gently slopes, or slightly contoured right-of-ways.
   / Rotary cutter options, driveline, tailwheel and guarding #20
I was referring to the tailwheel design as compared to similar units of other brands, and the LP is somewhat lacking in that regard... Not bashing Land Pride.. I love their implements and own a few.
2019 GEHL R105 WHEELED SKID STEER (A51242)
2019 GEHL R105...
2018 Chevrolet Silverado 3500HD 4x4 Crew Cab 9FT Flatbed Truck (A51692)
2018 Chevrolet...
2024 Mach Pro MPS330 Mini Stand-On Track Loader Skid Steer (A55787)
2024 Mach Pro...
PALLET OF SCAFFOLDING (APPROX. 21 PC) (A52706)
PALLET OF...
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB 3 Ton Crane Service Truck (A55788)
2013 Ford F-550...
1996 Allegheny 35ft 25 Ton Flatbed Equipment Trailer (A51692)
1996 Allegheny...
