Barn project - setting concrete piers
   / Barn project - setting concrete piers #12
I'm working through plans to erect a barn and there is something I haven't been able to "get a handle" on. I'm thinking of setting PT 6x6 posts on concrete piers as footings. How can I set the concrete piers or forms in place and be sure that the PT posts will all sit in perfect position, such that they will all be plum and aligned? I know how to "square up" a footing and align the holes for the piers, but it seems nearly impossible that you could fill tubes with wet concrete, insert post brackets, and have everything so precisely aligned that all of the columns would be perfectly plum when finished. If I set concrete piers like this for a large barn (say 28 x 40? with metal receptacles for the wood posts embedded in the concrete, I cannot image achieving the kind of precision needed to avoid having to tap the columns into plum.
Am I missing something here?
Thanks!
I use this method to lay out foundation posts
Just need 2x4s, a 25 ft steel tape and a 4-ft spirit level along with a bunch of flat steel stakes.
Good luck
   / Barn project - setting concrete piers #14
I am also "toying with" the idea of using laminated posts (i.e. using three or four 2x6s to sandwich together my posts. Any thoughts on that? It would make construction more managable for someone working alone.
I used a combination of glulam/nailam for the beams on my equipment shed--two 2x12 x 16 ft long glued with exterior grade wood glue and pattern nailed.
I've also make redwood posts for the gate to my Japanese garden using the glulam approach
   / Barn project - setting concrete piers #15
I just started a pole barn that is engineered for
140 winds on the Gulf Coast. In the plans, I had to suspend all 15 posts 8-10" from the bottom of 43" deep holes, 18-24" diameter. I uses 2x4's x 6'temp nailed 32" from bottom of posts. When plumbed and braced, the concrete flowed under the bottom of posts for a good footing. Poured each hole 2/3 with 2500 psi concrete then packed native soil to grade level. After it set, knocked the 2x4's off the posts. This worked great for my plans.
   / Barn project - setting concrete piers #16
I've replaced more porch posts then fence posts. Rot always happens at ground level. With porch posts, it's so much easier for moisture to get up into the post through the end grain and rot the wood long before you even know it's happening. With fence posts, it happens from standing water at the base of the post.
If you make sure that no water is ever at the base of the post, you will never have any problems. The reason some pole barns last forever and others have issues is because of drainage.
By pouring concrete and attaching your posts to the top of the concrete, you are losing all that strength that the post would have given your building by being in the ground. You are spending more money and you are taking more time to do it this way. Unless there is another reason that outweighs all the benifits of setting posts into the ground, I would never build a barn by setting the posts on concrete piers.
Eddie
Eddie
After lots of research, I have come to that same conclusion. I'm going to set my posts directly into the ground. My initial question is still relevant though, and I can see now how the posts can be set precisely in line so that everything comes out plum and square. The drainage issue is probably the best advice I have seen regarding wood piers. I plan to backfill the holes with crushed stone or gravel and landscape so that water will run away from the posts and not collect at the base. I'm still not clear though on whether a concrete footing is appropriate. My thinking is that perhaps I would be better off with six or eight inches of large stone (maybe 1 1/2") at the bottom of the hole. This would allow moisture to percolate down and away from the end grain of the posts.
   / Barn project - setting concrete piers #18
Most pole barn building companies use 16" concrete donuts at the bottom of the hole as a footing. In my area it is code. You may not be subject to code but to me there is no reason to out guess the engineers at the pole barn companies.
MarkV
   / Barn project - setting concrete piers #19
I am in the process of building my pole barn right now and set all my 6"x 6" in the ground. I actually threw a bag of concrete in the hole and set the post on top of it just to get a bigger base. All the pole barns around here that I know of just set the posts in the ground and there are some old barns around that are still solid as can be. I have build many decks over the last 25 years all with post set directly in the ground and have never heard of any that the post have rotted. Slope the grade away from the building and all should be fine. Good luck on the project!
Darren
   / Barn project - setting concrete piers #20
Around here, for decks, we nail the structure together and prop it up with all the posts hanging in their holes. So you use the actual squared-up frame to position the posts where they need to be, rather than doing in the other way around. Once it's ready, we pour concrete into the post holes so that it flows around and under the posts.
I plan to use the same procedure for my pole barn with some modifications. First, I will dig all the holes, and line the bottoms with some gravel and a small concrete pad for the post to sit on. Then all the posts will be put loose into the holes. One wall at a time, I will run purloins across the posts to square them up and form the basic wall frame. I'll join two walls at a corner, and do whatever jiggling needed to square up the corner and brace it with the posts roughly centered in the holes. Then do the opposite corner, and finally join the two remaining corners. Once everything is where I want it, I will fill the post holes (most likely with gravel, but concrete could be used as well).
With this approach, I plan to leave slop at the tops of the posts (so that all holes don't have to be perfectly leveled with each other) and then once the walls are framed and posts set, just lop off whatever extra post is left at the top.
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
UNUSED FUTURE XJ3T 3T HYD THUMB CLAMP (A57193)
UNUSED FUTURE XJ3T...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55851)
2025 Kivel 48in...
2020 DRAGON ESP...
2014 Ford F-150 Pickup Truck (A55852)
2014 Ford F-150...
2019 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A52707)
2019 CATERPILLAR...
