Hydraulic motor size
   / Hydraulic motor size #1
Rio_Grande
Anyone know what size hydraulic motor I need to drive a post hole auger through a gear box? I am wanting to convert a 3 point digger to a hydraulic. Figure if I add a gearbox to it and mount it from a plate it should work. Then I can use it on the front of my skid steer or tractor!
   / Hydraulic motor size #2
I'd be curious to see if there is some sort of formula that can be used to size a hydraulic motor. I've got a snowblower I've thought about converting over to hydraulic drive.
Any reason this wouldnt work JJ?
Surplus Center - 5.4 CU IN BUCHER BHB090A921200B HYD MOTOR
I will be connecting it to a straight shaft so there is not a need for the splined unit. Although that gives me a few ideas.
I intend to mount straight to the gearbox. then the rest of the unit will be mounted to the skid steer mount.
   / Hydraulic motor size #5
Just about any hyd motor in that range should work.
The rpm shown is for the GPM indicated, and if you can't provide the GPMs, it will run slower.
Will this motor be used with your track loader or something else.
I believe your loader puts out about 19.8 GPM at 2760 psi.
Here is a skidsteer adapter to power any of the 3pt implements you might have.
http://www.skidsteersolutions.com/ProductDetails.asp?ProductCode=EZ-3PT-80-S3
http://www.skidsteersolutions.com/Skid_Steer_LF_3_Point_Adaptors_s/53.htm
http://www.berlon.com/3pt.php
Yes it is primarily for the skid steer.
   / Hydraulic motor size #7
Here are some formulas.
Usually have to start by estimating torque or HP required and work back from that point.
  • Fluid_Power_Formulas_(pdf_216_kb).pdf
   / Hydraulic motor size #9
Would love to see some pix of the direct drive set up.
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
UNUSED SWICT 84" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 84"...
(APPROX. 15) UNUSED IRANCH GROUND PROTECTION MATS (A54757)
(APPROX. 15)...
2001 AMADAS 2100 LOT NUMBER 251 (A53084)
2001 AMADAS 2100...
2015 International 4400 SBA Gap Vac Truck (A53117)
2015 International...
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
