BX1500 first repair to be made to the deck.
   / BX1500 first repair to be made to the deck. #1
dex3361
Elite Member
N. of Charleston WV
Kubota L4400-1 HST,FEL, 3x3 remotes, TNT. BX1500 54 mmm
I was about half way through mowing and I heard a noise a sound and felt a vibration. I stopped and did a once over and found a spindle nut loose and the bearings were shot. I put in and order for bearings and seals so I guess it is time to do my first BX1500 repair. The tractor is a 2005 model and I think this is the original belt. Doesn't look to bad but since I will have it down to that point I will replace the $75 belt.
   / BX1500 first repair to be made to the deck. #2
How many hours do you have on your 1500? I am at 900 on my 2003 BX2200 and still using the original belt and spindles.
I used to slack the belt when I stored the deck over the winter, but I stopped doing that 5 years ago or so.
I have about 270 hours on it. It was formerly owned by JohnnThomas(TBN member). It only had 100 hours on it when I got it. I am going to rebuild both outside spindles as the right side seems a little rough. That way hopefully I will not have to fool with it for a while.
   / BX1500 first repair to be made to the deck. #4
Feel certain that is the original belt. Great mowing machine that I only changed oil and filters.
I am amazed at how well the little 2 cylinder diesel runs. I will have it back up and running next week after the parts come in. I used the new Kubota parts diagram and uploaded it to Messicks web site. It was a smooth process. It is a good tool for Kubota owners.
The Deck epair is all complete. While I was at it I changed the deck gear box oil. I was going to change the belt but thought I would run it a few more years. I also changed the primary fuel filter since the deck was off. Put it back together with freshly sharpened blades and mowed for about 4 hours. I was amazed at how much quieter it was. I guess it sneaked up on you:laughing:
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
Club Car Electric Golf Cart (A50121)
Club Car Electric...
Case Ih 1660 Combine (A50514)
Case Ih 1660...
2013 John Deere 544K Articulated Wheel Loader (A50322)
2013 John Deere...
1992 Imperial Trailer (A50514)
1992 Imperial...
2007 MACK CT713 ROLL OFF TRUCK (A52141)
2007 MACK CT713...
