Hydraulic PHD advice
   / Hydraulic PHD advice #1
rd_macgregor
Prince Edward Island, Canada
Kioti DK45SC, Kubota B2650
My wife and daughter want to put in a bunch more horse fencing and build an outdoor arena, so I'm using this as an excuse to get the hydraulic PHD that I've wanted.
Because I only have 9.8GPM of flow in my Kioti DK45, most skid-steer hydraulic augers wouldn't work well (if at all). I've priced the Belltec NC150 auger drive, which calls for 6-15 GPM, but am hung up on what size auger bits to order. My posts aren't likely to be set in concrete, just backfilled and tamped in, so should the holes be just slightly larger diameter than the posts or substantially larger? I'd like to get by with just two bits, but can't decide if I should go with 6 and 12 or 9 and 14 (we might be using some old utility poles for corner posts).
First, is there anyone here with experience with the Belltec hydraulic auger?
Second, I'd be happy to hear advice on pros and cons of bit size.
Oh, by the way, our soil is mostly sandy loam with sandstone cobbles (sometimes big chunks or even quite large sandstone slabs -- but pretty soft sandstone, for the most part); very little clay.
Thanks,
BOB
   / Hydraulic PHD advice #2
Thanks,
BOB
Just curious who told you that a skid steer auger won't work? If a skid steer has even 20GPM in the aux circuit [that is alot by the way] your tractor would spin it a half speed but it would still have plenty of torque at the 2600PSI relief setting. Most newer skid steers are around 2800-3200PSI so we are close with our tractors. I am renting 1 with a 30" bit in a couple of weeks, we'll see how that goes. CJ
My concern with the rotation rate is that it might not clear the dirt quite as well...it has to sort of fling the dirt off to the sides or else you just end up with a pile on the bit that falls back into the hole when you pull the bit up/out.
I think the Belltec NC-150, at my 9.88 GPM, would be turning at about 60 rpm with roughly 1200 ft-lbs of torque. The next model (NC-200, rated at 10-20 GPM) would turn at only about 50 rpm (but have closer to 1500 ft-lbs of torque).
The comparable Danuser augers (either EP-6 or Model 615) from Everything Attachments are very simlilar to the Belltecs in RPM and torque, but I can get the Belltec from a Canadian distributor with a bit less shipping hassle.
I've decided that I can afford the auger drive, with hex shaft, flat-face couplers and SS quick-attach plate AND two auger bits...I'm now dithering about which two bits to order, given my intended uses.
I'm not keen on doing a lot more backfilling and tamping than necessary, but I don't want to find I'm drilling holes 1/2" smaller diameter than my posts, either!
BOB
   / Hydraulic PHD advice #4
BOB,
I have the PA 30 hydraulic auger to use with my 110tlb and am using it with minimal flow rates. While it does turn slow it still seems to do a good job of clearing the dirt from the hole. I chose the more heavy duty model over the PA 15 because of prefering the extra torque over the higher turning speed. I figured that it would be easier to clean out a hole than to have to dig the hole by hand because of larger rocks.
After using the larger unit for two years I have had several holes that I don't think the smaller unit could have dug out. If you don't have any large rocks that would stop the auger drive then a faster speed with less torque would sling the dirt better as you mention. As long as the bit is turning with down pressure both will make the holes in a couple of seconds is my experience.
   / Hydraulic PHD advice #6
I built my own. Cost 1K all in. Used a wheel motor and hub, welded an adapter, bolted some bolts and it is the best darn tool for digging holes. This thing is a monster.
My tractor line is Hydraulic, there is a range of Hydraulic post hole diggers, from small ones for the machines with 4GPH to my size (18GPH).
Here is a picture of my results. Happy to help if you need more advice.
One other thing, I know very little about tractoring, and my first few post holes were not successful as they would fill back in. But then I learned something which was stop the drill when you get to what you want as a bottom, and lift it up (Auger not spinning) once it is out of the ground turn it on and fling the dirt off. Much cleaner holes.
As for bit size, I got a 12". A 14 would have been better in hindsight. I wish for a whole set of augers up to the 36" but I have a mortgage to pay. I think one 14" bit would be more than enough. Forget the 9"
   / Hydraulic PHD advice #7
I have a hydraulic auger on my 110 tlb, can't remember the name but it is almost identical spec wise to the PA 30. I use the same method as woodlandfarms, stop the bit at the bottom of the hole and lift up at the end; I then back up a foot so the dirt won't fall back in the hole and cycle the hydraulics back and forth a few times to knock all the dirt off. This gives the cleanest hole.
I have gravel and sand type soil, I find it can be a pain if the ground is very dry since the hole will collapse a little at times. I have a 9" bit, perfect for 4x4 posts but tight with the 6x6 posts I use in corners and gates. I will pick up a 12"+ at some point.
I have used 3 pt hitch ones before and find the hydraulic auger on the loader is much better, if I buy another tractor I will put the auger on the 110 backhoe for the extra flow rate. I like it in the loader for now due to the ease of hooking up and not needing the backhoe attached.
Another note of caution, my wife has a few horses. We have an outdoor arena and I find it is a waste of space. She doesn't ride in it much, mostly due to the dust the sand makes and the hassle of having to water it first. So she rides in the field and I have to drag the arena to keep the grass and weeds out of it. Would serve a much better purpose of being seeded over so the horses have more to eat (and I don't have to do anything to it).
ME83, if it was up to me, we wouldn't have horses at all! My wife would be content to ride trails and fields, but my daughter is training young horses and doesn't want them to be able to run off if she gets dumped. Also (purportedly), they need to be accustomed to arena-riding before going into competition.
Woodlandfarms, congratulations on fabricating your set-up. Sadly, I not only am seriously inept, mechanically, but I also don't really have tools or a good working setup (eg shop) to do that sort of thing. What sort of things have you been putting into your 14" holes? I'll be mostly installing fence posts in the 4" to 6" size, and didn't want to end up backfilling and tamping a lot extra. Still, maybe I'd be better (if I'm getting two bits) to go with the 9" and a 14-15" size rather than the 12"?? Is 14" big enough for tree/shrub planting?
BOB
   / Hydraulic PHD advice #10
BOB
Gotcha, I was told by the rental place that the auger on their skid steers will not clean themselfs out with anything over 12" dia. auger. I looked up the spec on their units and it is 16GPM flow. Anyway they said to load the auger then pull it away and dump it, doesn't seem to be a big problem but I will know in a few weeks!! CJ
2020 John Deere 9470RX Tractor (A53342)
2020 John Deere...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
2012 Dodge Grand Caravan Van (A51694)
2012 Dodge Grand...
2023 Jeep Compass Trail Hawk 4x4 SUV (A51694)
2023 Jeep Compass...
2009 Chevrolet Traverse LS SUV (A51694)
2009 Chevrolet...
