Need Help With Using a John Deere FBA Wheat Drill
   / Need Help With Using a John Deere FBA Wheat Drill #1
FFD
Jonesburg, MO
New Holland TC30
Hi Everybody!
I just purchased a John Deere FBA Wheat Drill and need help on how to use it to plant soybeans.
It has the charts inside the lids of the seed bins. I'm just not sure I understand what it is saying on how to set it. I know you use the levers on the rear of the drill to set the rate and you have to adjust the the tin plate levers at each seed shoot for the size of seed.
But what do the levers on the side of the seed bins do?
I have 6 acres I want to plant in beans. Just looking for any help as I want to plant this weekend and hoping not to spend alot of time trying to guess at how it works.
Also where might I get a user's manual for it.
Thank you all for any help with this!
Jeff
   / Need Help With Using a John Deere FBA Wheat Drill #2
Welcome to TBN. :)
   / Need Help With Using a John Deere FBA Wheat Drill #3
Welcome to TBN from Oklahoma.
Ken
   / Need Help With Using a John Deere FBA Wheat Drill #4
Welcome to TBN :)
I moved your thread to the Ag Tractors & Machinery Forum.
   / Need Help With Using a John Deere FBA Wheat Drill #6
The levers at the back, side corners are the feed control for the fertilizer section. The picture below shows the seed lever under the lower left, and the fertilizer on the left side pointing towards the back. That drill is a JD/VB FB, which is very similar to an FB-A.
They are very simple drills, not a whole lot to figure out. Here's a link to an ebay auction for one.
John Deere Van Brunt Model FB-A Grain Drill Operator's manual Original | eBay
I found this one in a fence row, all bunged up, bent frame and broken gears on the passenger side. Cut it about in half, made a sweet little drill. HTH Mark
   / Need Help With Using a John Deere FBA Wheat Drill #7
Nice job:thumbsup:
JOHN DEERE 6155M (A53084)
JOHN DEERE 6155M...
2018 Gatormade 20+5 Gooseneck Trailer (A53472)
2018 Gatormade...
2020 BERGMANN C815S DUMP TRUCK (A51246)
2020 BERGMANN...
UNUSED WOLVERINE CB-11-750F HYD CONCRETE BREAKER (A51248)
UNUSED WOLVERINE...
2012 Ford F-250 Pickup Truck (A51692)
2012 Ford F-250...
2018 JOHN DEERE 317G SKID STEER (A51246)
2018 JOHN DEERE...
