Fluid ballast in tires
   / Fluid ballast in tires #11
could someone tell me the cost to fill rear tires? 3032 here haven't picked it up yet.(next week)
   / Fluid ballast in tires #12
It's going to vary on the dealer, some will do it for the cost of the material and others charge you a regular service rate plus the cost, and others will charge you labor rate and retail on the material.
My dealer charged me $350 for my 2520.
   / Fluid ballast in tires #13
I own a 2520 with and FEL and for the most part agree with folks that a loaded ballast box and filled tires or wheel weights are the way to go... even says so in the Deere manual.
However, in my application, I wanted the tractor as light as possible to cut the fine fescue grass on my delicate lawn without leaving tread marks (R4s) or compressing the dirt.
So I elected to add an extension to the ballast box so I could load it to near 1,000 pounds. With this setup, non-filled tires and no wheel weights, I have been unable to lift the rear wheels off the ground with the heaviest of FEL loads. In fact, I'll lose hydraulic lifting capacity (lever full aft) well before the rear-end even begins to budge.
For cutting grass, I remove the FEL and ballast box and voila' light tractor. Obviously your mileage will vary.
1984 Ford LTD Crown Victoria (A52377)
1984 Ford LTD...
2014 Dodge Ram 4500 Versalift Bucket Truck (A52377)
2014 Dodge Ram...
Chevrolet C8500 Flat Bed with a Moffet Kit (A55218)
Chevrolet C8500...
2013 Nissan Rouge SUV (A53424)
2013 Nissan Rouge...
1999 Ford F-550 12FT. Flatbed Truck (A51692)
1999 Ford F-550...
