Fluid ballast in tires
   / Fluid ballast in tires #11
could someone tell me the cost to fill rear tires? 3032 here haven't picked it up yet.(next week)
   / Fluid ballast in tires #12
It's going to vary on the dealer, some will do it for the cost of the material and others charge you a regular service rate plus the cost, and others will charge you labor rate and retail on the material.
My dealer charged me $350 for my 2520.
   / Fluid ballast in tires #13
I own a 2520 with and FEL and for the most part agree with folks that a loaded ballast box and filled tires or wheel weights are the way to go... even says so in the Deere manual.
However, in my application, I wanted the tractor as light as possible to cut the fine fescue grass on my delicate lawn without leaving tread marks (R4s) or compressing the dirt.
So I elected to add an extension to the ballast box so I could load it to near 1,000 pounds. With this setup, non-filled tires and no wheel weights, I have been unable to lift the rear wheels off the ground with the heaviest of FEL loads. In fact, I'll lose hydraulic lifting capacity (lever full aft) well before the rear-end even begins to budge.
For cutting grass, I remove the FEL and ballast box and voila' light tractor. Obviously your mileage will vary.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
UNUSED RAYTREE RMA42 HYD AUGER (A54757)
UNUSED RAYTREE...
2000 Ford F-550 Altec AT35-G 35ft Bucket Truck (A53422)
2000 Ford F-550...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
BUYERS PREMIUM & PAYMENT TERMS (A54607)
BUYERS PREMIUM &...
2015 Land Rover Evoque SUV (A53424)
2015 Land Rover...
