Long tractor model 610 oil leak
   / Long tractor model 610 oil leak #1
asandy
Afton VA
long 610
I'm looking at a long tractor modle610 that looks to be in good shape except it has a steady oil leak coming from between the engine block and the bell housing about half way up on the left side just above the oil pan but not coming from the oil pan. I suspect it is coming from an oil plug in the back of the block.. Any one ever run into this one before? If so please send some help,,
I've pulled wrenches all my life so splitting this thing in half doesn't bother me just like to get an idea what I'm looking at. Thanks Allan
   / Long tractor model 610 oil leak #2
Welcome to TBN. :)
   / Long tractor model 610 oil leak #3
Welcome to TBN from Oklahoma.
Ken
   / Long tractor model 610 oil leak #5
Welcome to TBN :)
I moved your thread to the Parts/Repairs Forum.
   / Long tractor model 610 oil leak #6
check the engine oil and hyd oil. one will be low if the engine oil is low its the rear main seal if the hyd oil is low then its the input shaft seal in the trans either way the tractor has to be split
   / Long tractor model 610 oil leak #7
Did this issue get figured out..?? I have one doing the same thing.. Thanks
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
PENDING SELLER CONFIRMATIONS (A54607)
PENDING SELLER...
Kubota SVL95-2 High Flow Cab Skid Steer (A55218)
Kubota SVL95-2...
JLG 1255 Telehandler (A55218)
JLG 1255...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
2025 Wolverine BC-13-72W 66in Brush Cutter Skid Steer Attachment (A52378)
2025 Wolverine...
