Gas can fix
   / Gas can fix #3
That valve stem, what might some of the stores be that would carry it?
   / Gas can fix #5
Any auto parts store should have them. I think that Walmart even has them. It is just a standard valve stem for a tubeless tire. I picked up a couple at Orielly auto parts. I think the ones that I used are 1in long.
   / Gas can fix #6
Thanks, Mike. Already done that using a shorter valve stem that was the metal bolt on fit type. I hope the diesel doesn't dissolve the rubber interface with the container(over time that is). At 80 years old and 145 lbs, lifting 5 gallons of diesel is getting to be quite a chore. So the alterations make it go better. I also use a two foot tall stool to prop the jug on my leg on while filling.... works good rotating stored gasoline that's moved into my truck too. Mike oldballs
   / Gas can fix #7
There are a number of youtube videos on the subject, all a variation on the same theme. Apparently lots of folks have trouble with the inane EPA compliant designs.
   / Gas can fix #8
I've spilled more in a few years with the EPA cans because they don't seal tight on the tube than I did in the rest of my life. And I always capped my old cans so I doubt much evaporated. Faulty design that does the opposite of what it is supposed to do.
   / Gas can fix
Something we can all agree on... There is hope :)
   / Gas can fix #10
Are you referring to the EPA in general or just the gas can :)
2006 CATERPILLAR 312CL EXCAVATOR (A51406)
2006 CATERPILLAR...
Adams 5 T Spreader (A55301)
Adams 5 T Spreader...
AT 26in x 11-12in (A52377)
AT 26in x 11-12in...
2010 American LaFrance Condor MRL Long Line Tri-Axle Thermoplastic Striping Truck (A52377)
2010 American...
2012 Freightliner M2 Chipper Truck (A52377)
2012 Freightliner...
