Molerj
- Joined
- Jul 18, 2001
- Messages
- 609
- Location
- Eastern Ohio
- Tractor
- JD 955, 1978 Economy Power King, JD X500
Yes it is. Put in your model-- John Deere - Parts Catalog
Also 210 hrs is just broke in, if you take good care out it, it should last 1500 to 2000 hrs on the motor and the deck may need rebuilt a little sooner.
WOW!!
That deck has been through **** and back.
Where has it been, and what has it been through?
Sorry, but it is not a tank.
Shocked that 210 hours can lead to that much torture.
Now to get you some help.
I'd take it to a good welder and ask if he/she would weld it back into some semblence of wholeness.
There isn't an issue of timing, as there is offset in the blades so they cannot touch. But I'd suspect something has bent the deck and/or the spindles that the blades are not running in the same plane.
While off, rotate a blade around to see if the tips pass each other in the same plane. Do it for each combination of the 4 tips. Hope that it may just be a bent blade such that replacement blades will fix the problem.
I'd clean it(top/bottom). Pull that cover off see what it looks like underneath.
Fill grease fittings put on new belt/blades . Weld or brace that grass chute bar.
Oil good and give it a whirl. I suspect when you slap it all together it will be fine. Check to make sure blades have to be set correct or same way.
Store indoors if you don't already.
Hide keys maybe that fox has been taken it for joyrides !
Wishing You and Family The Best !
Boone
