Rylee Root Ripper
   / Rylee Root Ripper #1
dustinfox
Gold Member
New Hampshire
Kioti CK35 HST
All I can say is, after digging with my bucket and toothbar, this thing is fantastic! Dug out this 18" stump (freshly cut) in about an hour.
   / Rylee Root Ripper
Think I maxed out the lift on my CK35.
   / Rylee Root Ripper #3
Thats a pretty good stump - fir or spruce maybe?
Looks like a good tool to have.
Can you drive that root ripper right into the ground ?
   / Rylee Root Ripper #4
How much does it weigh and how long is the snout? Is it made from 3/8" or 1/2" material?
   / Rylee Root Ripper
It's a spruce. It's like having a giant shovel on the end of my tractor. The tip is 6" wide and yes, I can drive it into the ground like a spade. Still take a lot of digging to get all the roots exposed but sure beats using a hand shovel!
   / Rylee Root Ripper
   / Rylee Root Ripper #7
Bucket Solutions clamp-on "Bucket Spade" is a variation on the theme; lighter, though @ 110 pounds.
Tractor Forks, Bucket Forks, Loader Forks
I attach my bucket spade to a Kubota B3300SU / 33-hp / 25-hp PTO.
You would think it might loosen up in use....but it NEVER has.
   / Rylee Root Ripper
I was looking at that but I liked the "teeth" on the Rylee bucket. They help to cut the roots off when digging around a stump.
   / Rylee Root Ripper #9
With it directly in front of the tractor, how hard is it to see where you are digging? looks like it would be great on a skid steer.
   / Rylee Root Ripper
It can be a little difficult to see where the tip makes ground contact. Sometimes when I want to make a plunge I need to get up and look over the tractor to get the front edge where I want it. Still beats using a shovel though.
   / Rylee Root Ripper #11
That looks like a cool implement, never seen such a thing.
   / Rylee Root Ripper #12
I have something similar. Here is a video of my first practice cedar.
[ame=http://www.youtube.com/watch?v=PnEGPk6NQh0]Tree Spade Demo - YouTube[/ame]
I just bought a DFM Turbo Saw for the 3 point and will pick it up this weekend.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
2022 THOMPSON PUMP 6X6S1 PORTABLE PUMP (A59823)
2022 THOMPSON PUMP...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
INGERSOLL RAND WL-440 WHEEL LOADER (A60429)
INGERSOLL RAND...
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
