Carl_NH
Elite Member
- Joined
- Apr 5, 2002
- Messages
- 3,919
- Location
- Coastal NH
- Tractor
- 01 Kubota B21TLB, 2010 Ferris 52" ZTR, Cub Cadet 1811, Gravely Super8
Wade,
There should be two levels of water - static when not pumping then after drawdown. I would also contact the driller of the well - usually they put their tag on the tank or wellhead.
So this AM you can drop a line with a small nut attached and determine when it hits water for the static level - should be about 80-100' leaving you with 250' of water or about 400 gallons of reserve (1.5 gal / ft in a 6" casing). Then the recovery rate is how fast the inflow to the well is - most well drillers would not consider a 1.5-2GPM sufficient for a house so they drill deeper to create more storage and or find a better vein of water.
I have a deep well 400 feet with the pump set at 365 with a 1.5HP goulds 2 wire. Also have a low pressure cutout switch so when the pump output drops below 15-20 PSI the switch turns off the pump to prevent damaging the pump.
There is a somewhat controversial method I posted some time ago "stone drop method" to determine water level. My pump guy (doing it 30 yrs) say a rough calculation of water level is to drop a pebble in the well, and time it. Typically its 20' a second so 5 seconds tiil you hear it hit water is 100' water level. Instead of a stone drop an ice cube too. This has worked for me and I use this as a simple check for the water level.
The bottom line is you should put in a low pressure cutout switch in place of the existing pressure switch and sounds like a new pump too. Pulling 350' of pump is not easy.. Also when you put in the new one, make sure the pipe is clean and free from grass and debris before installing.
Carl
Carl
