Well pump keeps going out!! 4 in last 6 years!
   / Well pump keeps going out!! 4 in last 6 years! #21
Hey guys! WOW thanks for all the detailed posts!!! Here is what appears to have happened. When the well pump was kicking on it was banging against the side in several places and broke the wire about 5 feet above the pump. The wire was also skint up in several other places. After pulling the pump up I ran new wire and added those white plastic bumpers that the pipe goes through. I now have water!!!!:thumbsup:
The well is 358 feet total. The pump hits the water at about 80 feet so I have well over 200 feet above the head. It is a 3 wire 10 guage system on a Myers 1hp pump.
Thank you all for the replies!:thumbsup:
Wade
That sounds better - thanks for the update - you have a 2 wire motor it appears (no control box above ground).
Also good to put on the plastic spacers but better to install a torque arrestor (expandable rubber) above the pump a few feet then about 150' midway on the pipe. This prevents the twisting and wearing of the wire on the casing when the water level is low.
Also replace your pressure switch with a low pressure cutout type and as others have suggested check the charge (Storage) tank pressure and even add another tank to decrease the cycles of the pump. The switch should be set at 40 PSI and the charge tank pressure (tank empty 38PSI) or 2 PSI below the cutin on the switch.
Glad you have water again, but these measures should give you a water system that lasts 5-10 years before needing servicing.
Carl
   / Well pump keeps going out!! 4 in last 6 years! #22
Dang it, I thought that those plastic "no-spin" discs were SOP on any pump install.....I didn't even consider that
   / Well pump keeps going out!! 4 in last 6 years! #23
are you reusing the old wire?
do you run irrigation?
geting sand?
   / Well pump keeps going out!! 4 in last 6 years! #24
I had a well that had less flow than was needed, however at the time I could not afford to either drill or fracture the well. The solution I finally used was a load sensing switch on the pump. The switch would detect the drop in load when the well ran out of water and stopped the pump for a set period of time like a half an hour or so, I think it was adjustable, then cycle back on until the tank was full. Worked, and is still working, for fifteen years. It works great and never had to worry about running the pump dry.
   / Well pump keeps going out!! 4 in last 6 years! #25
Wade
Good setup. You should have no trouble for 20yrs. Too late now, but there are torque snubbers for the pipe that damp the quick twist that happens as the pump starts. Using these near the pump is good.
larry
   / Well pump keeps going out!! 4 in last 6 years! #26
Wade
Good setup. You should have no trouble for 20yrs. Too late now, but there are torque snubbers for the pipe that damp the quick twist that happens as the pump starts. Using these around the tubing near the pump is good.
larry
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
1990 GREAT DANE 28' REFER (A52472)
1990 GREAT DANE...
2003 VIKING  CEMENT MIXING TRAILER (A52472)
2003 VIKING...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
T3 Motion Patroller Segway (A51694)
T3 Motion...
