Why not use a finish mower
   / Why not use a finish mower #51
Just bought it so the grass was tall as He@$ but its not considered a small gear box for its size, really small ones i saw where on new ones in the same price range, The gears look Huge compared to the landpride 5 footer i looked at. But your right i am sure its not meant to cut tall grass, but now its knocked down i can maintain it. Its difficult to find info on the 261 JD but older folks have told me there pretty tough, so well see.
Your right, its not a "small" gear box....but compaired to a bushhog........
Here's the update. Dealer is bringing a flail mower this weekend for me to try out. I admit to being curious. It's a 2009 model sold as used but with full warranty so a good deal and priced less than a new finish mower. Thanks for all the good advice.
   / Why not use a finish mower #53
Let us know how it works out
   / Why not use a finish mower #54
I'm surprised this thread has not gotten over to the subject of "not all RFM's are created equal". There are RFM's and then there is the Woods RM990, a heavy-duty commercial-quality unit with swing-back blades. If you search TBN for RM990 you'll find lots to read. I've used RM990's for many years on my old orchard land which has evolved to look quite good. I set the height to 5-1/2" which makes a good job without making the mower do earthwork.
   / Why not use a finish mower #55
rbargeron
That's the one I have used for 20 years and described earlier in this thread.
Others on here argue, "look at the name, Finish Mower" and other reasons not too use one, based just on their own limited experiences or equipment.
As I recall the OP has both a finish mower and a bushog and I urged him to try a couple acres with each to see what can be done with his equipment.
Some don't seem to realize that finish mowers would not have height adjustments of up to 8" for cutting lawn grass. I recently cut a field that had hay grass 36" high that had gone too much past prime down to 6" with my Woods and will cut it again to 3.5" if we ever get any rain. It will rot in well and disappear after 2 cuts and some rain. With a bushog it would look lousy all summer regardless of how many more times it is cut. I used to do it that way, so know from experience. Bushog blades are dull and have no suction so they do not recut the stuff already except for the windrows that are created in strips. Even then it is mostly just spread around like a tedder would do.
We keep a fenced horse pasture cut to 3.5" starting in early spring to avoid
green grass colic of the pig eating horses and to keep the weeds gone. The blades spread the horse apples at the same time.
But as you said, the Woods is built tuff with a wide B belt and sheaves that have large tapered roller bearings. It weighs 1,000 pounds.
I'm really surprised to see this thread grinding on and on. If the equipment is built to take it, use common sense and listen to the tractor and mower, try both ways and see. Or do a bushog first and follow with a finish mower. If you want it to look good continue with the finish mower every couple weeks depending on the rain and growth.
   / Why not use a finish mower #56
pacerron - nice post. The RM990 cuts 7-1/2' - your earlier post mentioned an 8-foot so I thought it might be a different model.
I've used RM990's for 15 years. I got a fresh one a few years ago - the older one is semi-retired but still works fine. The 990's do it all - with low maintenance cost.
The flail worked out really well. In a couple pastures that I had mowed 3 weeks ago, the grass was only 6-7" tall and the flail did a great job. Even distribution of clippings, and broke up a lot of the residual windrows left over from the last 2 rotary cuttings. On the pasture with the tallest grass (about 24") it didn't do as nice a job (finish look) but if definitely handled the tall stuff without much effort. I will probably go over it a 2nd time in the next week or so.
The deal was too good to pass up on the flail - 2 year old, new on the pallet, sold for used price. Dealer took my rotary in trade so even better.
   / Why not use a finish mower #58
awesome :thumbsup:
2017 Freightliner 114SD Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A55852)
2017 Freightliner...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
KIDS DIRT BIKE (A53424)
KIDS DIRT BIKE...
2004 Pierce Tilt Crew Cab Pumper Fire Truck (A55852)
2004 Pierce Tilt...
Metal Trump 2028 Wall Art (A55853)
Metal Trump 2028...
23110 (A53424)
23110 (A53424)
