What is in the water?
   / What is in the water? #1
Darrenone
Tully, NY
Kabota L3130
I had a small pond dug last summer and the water that seeps out the sides is a strange color. Does anyone have any ideas? Thanks.
   / What is in the water? #2
I'd say it's leaching something out of the soil, why do you think it's in the water?
Where ever the water comes out and pools ( alot of clay ) it turns this color. I guess I just assumed it was something in the water.
   / What is in the water? #4
Could likely be either iron or tannic acid from decomposing vegetation, based on the color...
   / What is in the water? #6
Is this pond charged by rain water or a spring? I don't think rainwater has iron in it. Not sure how water picks up iron, I assume it has to sit long enough for it to dissolve minerals in the soil and rocks.
   / What is in the water? #7
It could be manganese as well, often the stuff will float on top, looks like an oil spill until you notice that it doesn't spread around much.
Sean
Thanks for the responses and BeezFun the pond catches alot of run off when it rains but there are alot of small springs all over the hill. Where a spring comes to the surface and goes across fresh dirt, it changes to this color. Next question would be if it is iron, is there any negative affects to say like swimming in it?
Sean
Hey Chilly807, that is exactly what it looks like. Kind of floats on top and looks like oil. Was kind of hoping it was oil and I was like the Beverly hillbillies... Is this bad to say like swim in?
   / What is in the water? #10
It won't hurt you, but will turn permed hair some unusual colours. If it is manganese, and is floating on top, you can separate it with a stick or something like that. Oil would just keep spreading, manganese won't since it's a mineral.
Mind you, if I'm wrong and it is something toxic, you're taking your chances.
Sean
2020 Bobcat MT85 (A53317)
2020 Bobcat MT85...
2022 CATERPILLAR 299D3 SKID STEER (A52707)
2022 CATERPILLAR...
UNUSED FUTURE CL100 HYD CLAMP GRABBER (A57193)
UNUSED FUTURE...
2018 JLG 3246ES 32ft Electric Scissor Lift (A53421)
2018 JLG 3246ES...
UNUSED FUTURE FT-ZP20 20' X 30' GARAGE CARPORT (A57193)
UNUSED FUTURE...
2007 Ford Focus Hatchback (A55853)
2007 Ford Focus...
