Minial
If i take the arm lift lever to high the engine will stall..at the moment i have to stop maybe an inch or more before the top of the quadrant to stop it stalling..anyone out there with ideas as to what is causing this to happen?
Minial said:If i take the arm lift lever to high the engine will stall..at the moment i have to stop maybe an inch or more before the top of the quadrant to stop it stalling..anyone out there with ideas as to what is causing this to happen?
No i don't have a manual as yet ..all the ones i've managed to check out online the diagrams haven't been that easy to read
Well, if could be that:
using "relativity", maybe you can adjust the part that your control levers run in so that the control lever does not go as far up. What I'm saying sounds like I'm being silly, but it could work maybe.
