sub soiler from TSC
   / sub soiler from TSC #1
mikim
Paige Texas
NH TC45
Bought a sub soiler from TSC to do some light trenching and 100' later took it back with a busted weld. I heard "snap" and looked just in time to see it twist into a pretzel. The weld was just awful. I can do better and I'm awful. They gave me my money back no problem. Now what do I do about the trenching? Trying to avoid the backhoe -- too time consuming and too big a trench for what I'm doing. They'll have a resupply at TSC in 2 weeks.....do I give 'em another chance at me?
   / sub soiler from TSC #2
Same thing happened to mine... looked back and noticed the paint cracking and peeling.
   / sub soiler from TSC #3
I have one almost like it and i've abused it terribly. I have not broke it but the paint is junk! All i can say is it i buy for a cheap price and it breaks, i'll straighten it up and reweld it so its right. This ordeal is common for me, i don't think much about it . . .John
   / sub soiler from TSC #5
I built mine and it is strong enough to stop the tractor in its tracks:
OK...so I can either spend enough to not be disappointed again...or buy the same cheapo + a welder to fix it each time it breaks.......guess I need to think about this.
   / sub soiler from TSC #7
I like the way that looks and I know it will hold up for the jobs we all have to doaround the place. How deep will it go and what did it cost to make ?
Farmboy from Mississippi
   / sub soiler from TSC #8
Or you buy another one and beef it up before you use it. Shouldn't have to but I have a feeling that it was designed for people with scut and light weight cut tractors.
   / sub soiler from TSC #9
Farmboy, if your referring to the one I built. I really cannot say how much it cost. I had some steel and did buy some to build the thing. And, I guess senility is setting in because I can't say how deep it will go. But, it has done everything I have asked of it so far. I don't use it very often but when I do need it the thing is there. Wish I could be more specific about the particulars you were wanted. :eek:
   / sub soiler from TSC #10
All subsoilers should have a shearpin engineered into the basic design... Ken Sweet
I agree, subsoilers should have a shear pin in their design. Better to break a shear pin than to destroy your subsoiler.
   / sub soiler from TSC #11
John Deere makes one to fit your 45 Hp. new holland. The same one will work well with a 140 Hp. tractor, just in case you up-grade some day. They call it a "single shank 22B Integral Ripper" and you can get an optional 31 pound mole ball that works good for draining wet spots or pulling cable/pipe.
The only bad part is that it costs more than the ones TSC sells.
If I had 8 feet of topsoil like y'all I probably wouldn't have broke it in the first place. I was dragging through clay....which shouldn't have broke it but did. (my sister still lives just east of marion)
   / sub soiler from TSC #13
New Fred Cain 1 Sk Subsoiler 3 Point, FREE SHIP 1000 Mi | eBay
All subsoilers should have a shearpin engineered into the basic design. The Fred Cain type subsoiler has been in production and successful use for over 30 years. Ken Sweet
... or you could get the "cheapo" and use that as an excuse to buy the welder so you can modify it to have a shear pin. You wouldn't believe what I can justify buying for my tractor ...
   / sub soiler from TSC #14
you can rent a mini excavator, if you are needing to go through roots and rocks within the ground. mini excavator = backhoe and nothing else exception a little push blade on front. to push dirt back into the trench.
or you can rent a trenching machine (that has a chain saw looking blade) if you have a good amount of trench, you can get self propelled walk behinds, to bigger machines that you ride on.
possibly rent a ditch witch, that has a small backhoe on one end, and then a chain saw looking blade on other end. plus blade on one of the ends to help push dirt back into the trench.
check some rental places, even those a couple hours away, prices can range big time. and check for discounts for 2 day, 3 day, weekly rates. you might also try some local tractor dealers. they may rent some stuff out as well.
if you do not have a trailer, but have a truck you can tow with, you can normally rent a trailer at same time getting a rental machine. (double check though not always have an extra trailer available) or have machine delivered.
   / sub soiler from TSC #15
Do any of you guys use a tiller behind your tractor? I have a 4025 Mihindra and a R1303 tiller (Yamar) and it works extremely well since I have modified it with the help of my brother and his welding skills. I always subsoil the ground in a checker board layout before I use the tiller to prepare for planting.
Farmboyin Seminary, MS
   / sub soiler from TSC #16
I have a "home made" unit made out of a box blade shank.
Also a home made middle buster out of a 10" cultivator.
That fits to my home made 3pt receiver hitch.
Have buried them up to the draw bar many times.
Pulled up rocks the size of basket balls.
And cut tree roots up to 4" diameter with the subsoiler.
I just go slow and if the tractor stops moving it will spin, and take a
less deep bite there.
Cross fingers, haven't had any trouble yet.
Will try and post a picture.
   / sub soiler from TSC #17
You sure did a great job building those tools. Looks like they work great also. Show me some more of that great American skill if you have build any more tools.
Farmboy
   / sub soiler from TSC #18
You guys be careful with plows and subsoilers that don't trip or have a shearpin. We hear of experienced farmers hitting rocks and being thrown into the steering wheel. Broken ribs are not unheard of. Ken Sweet
   / sub soiler from TSC #19
I have one of those TSC subsoilers for light duty work emphasis on "light" being the key.
Here is a good Deere subsoiler for pulling in pipe and wires and for heavy subsoiling.
   / sub soiler from TSC #20
so really that warning should read.
dont worry about the implement you have on the back designed to do what your doing with it. but remember to wear your seat belt like you should be doing because if you hit an immovable object your tractor WILL come to a sudden stop.
In my case with the subsoiler i use, I generally run my tractor at its traction limit so im hardly moveing pulling it through the ground... so the idea of "stoping quickly" doesnt really exist.
2021 CATERPILLAR 299D3 SKID STEER (A60429)
2021 CATERPILLAR...
2025 Swict 84in Bucket Skid Steer Attachment (A59228)
2025 Swict 84in...
MINI EXCAVATOR WOOD GRAPPLE (A60430)
MINI EXCAVATOR...
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
2014 Dodge Journey Van (A59231)
2014 Dodge Journey...
