A Million Models, Someone Cut Through the BS
   / A Million Models, Someone Cut Through the BS #11
If you're coming out of a BobCat tractor you're coming out of a KIOTI. Yours just had a few decals and different color paint...
I would suggest a DK 45HST.. The money is right. I use my DK 40HST every day hard. Its amazing IMHO.. Good luck on your research and decision.
   / A Million Models, Someone Cut Through the BS #12
Well, if physical size in a tractor is important to you for some reason then that pretty much seals it. You may want to look at Mahindra or Kioti.
If you want to be able to do more work with the same physically sized tractor then Kubota may have what you want in the MX5100. If you want something larger in physical size then there must be a logical reason.
More loader requires a larger hydraulic pump if you are lifting heavy materials. If it is just feathers then a huge QA bucket would work fine.
Have you researched the loaders available for the tractors that interest you?
The MX5100 will have more HP, more bucket capacity, more breakout force in my limited research.
A DK45 is the same frame as the 335, with just a few more HP. The next step up is the DK55
2018 INTERNATIONAL LT625 (A53843)
2018 INTERNATIONAL...
John Deere 6120E (A50323)
John Deere 6120E...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
11 10 FOOT BY 5 FOOT LIVESTOCK PANELS (A53843)
11 10 FOOT BY 5...
Kivel 48'' pallet fork attachment, 3500# capacity (A53421)
Kivel 48'' pallet...
