A Million Models, Someone Cut Through the BS
   / A Million Models, Someone Cut Through the BS #11
If you're coming out of a BobCat tractor you're coming out of a KIOTI. Yours just had a few decals and different color paint...
I would suggest a DK 45HST.. The money is right. I use my DK 40HST every day hard. Its amazing IMHO.. Good luck on your research and decision.
   / A Million Models, Someone Cut Through the BS #12
Well, if physical size in a tractor is important to you for some reason then that pretty much seals it. You may want to look at Mahindra or Kioti.
If you want to be able to do more work with the same physically sized tractor then Kubota may have what you want in the MX5100. If you want something larger in physical size then there must be a logical reason.
More loader requires a larger hydraulic pump if you are lifting heavy materials. If it is just feathers then a huge QA bucket would work fine.
Have you researched the loaders available for the tractors that interest you?
The MX5100 will have more HP, more bucket capacity, more breakout force in my limited research.
A DK45 is the same frame as the 335, with just a few more HP. The next step up is the DK55
John Deere MX10 Rotary Cutter (A53117)
John Deere MX10...
1981 Mack CF611F Fire Truck (A53117)
1981 Mack CF611F...
UNUSED Clear Multi-wall Polycarbonate Pane (A53117)
UNUSED Clear...
2023 MAXEY G8X 26FT TILT BED GOOSENECK TRAILER (A54607)
2023 MAXEY G8X...
Tailgate For Pickup Truck (A53117)
Tailgate For...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
